did you flash the new cwm_froyo.tar through ODIN? If not, here it is:Interesting. When I boot with power and volume up and down, when I apply update.zip it takes me to green. Do I need to apply update.zip from green also??
I'm having q problem with sc 2.1 I installed and when I went to the market then my apps none of my apps are there but I still can use them. Please help. !!!
From what I read, it seems like the problem is not so much flashing to Froyo with green, it's not being able to flash anything in Froyo using the green.I flashed the all in one that Cory put up... I just loaded SuperClean 2.1 with no issue though....hmmmmmmmm
Did you back them up first? Using Titanium or something?
Updated to 2.1.
I don't normally do stuff like this, but if you feel the need to donate to the "get my wife a nook color for valentine's day fund), my email address is adrynalyne at gmail dot com 9or my sig). Im about 90 short.
If not, thats cool too!
Voodoo and non voodoo superclean versions have been posted. Both flash working recoveries.
sweet. If you use rom manager you can also download the update.zip file to your clockwork folder, delete the recovery-update file that is there and rename the update.zip as recovery-update. That way you will reboot into red no matter what method you use.I managed to get to red. Wiped cache and data and such.
Adrynalyne
A few things I noticed:
1. When I power on my phone the Samsung logo is displayed and then the screen goes blank until it boots up. When I go into cwm I see a few messages: "E: Missing bitmap progress_empty (Code -1)" and "E: Missing bitmap progress_fill (Code -1). Is anyone else experiencing this?
2. I also can't get my wallpaper to display on my lock screen. Its just solid black. Any ideas?
Thanks for all of your hard work!
That was covered previously in.....I can't remember which thread because I've been reading so many of them. I believe everyone should be seeing those "error" mesages. It has to do with voodoo, but you are fine.When I power on my phone the Samsung logo is displayed and then the screen goes blank until it boots up. When I go into cwm I see a few messages: "E: Missing bitmap progress_empty (Code -1)" and "E: Missing bitmap progress_fill (Code -1). Is anyone else experiencing this?
