mcnasty150
Has any1 had this happen, flash vodoo with cwr red, after the install everything went the way it was suppose to rebooted , went into cwr and it was orange. anyway to get it back to red
Has any 1 had this happen, flash vodoo with cwr red, after the install everything went the way it was suppose to rebooted , went into cwr and it was orange. anyway to get it back to red
can anyone else not paste apps to system/apps in root explorer while on EB16 kernel? When I reflashed SC 2.9 it worked again.
O
Did you happen to use ROM manager?
Sent from my SCH-I500 using Tapatalk
Yes, sorry for the slow post been at work since 1.
I was on SC 2.9 voodoo and I just attempted to flash the updated kernel voodoo ..how can I tell if it was a success? I orig booted into red recovery but then it changed to orange?
Did it change to Orange because you booted directly to red first then scrolled to apply sdcard:update.zip? If so that's not what you need to do when you boot directly to red cwm. Read this thread by DroidXcon:
http://forum.androidcentral.com/ver...-clockworkmod-recovery-w-screen-captures.html
and you will need to reflash the cwm-all file in ODIN. And you have orange because you flashed clockworkmod recovery in rom manager. Leave rom manager alone for now, it is not working for the Fascinate. And you can't use orange cwm to flash anything right now. Orange no workie.
Yes, it originally booted into red then it changed to orange when I chose apply sdcard:update ..I'm just trying to flash the updated eb16 kernel with the bw fixes
Read DroidXcon's thread I linked you. You only used apply sdcard:update.zip in stock blue recovery. When you boot directly to red you just scroll to install zip from sd card, hit power button, scroll to choose zip from sd card, power button, scroll to wherever the EB16 zip file is, power button.
And for the love of all that is holy in Android, don't touch rom manager for now
Ok, I did the install from sd card, choose zip from sd, selected eb16, then it took me to install & I selected that, then my screen went black with blue letters flashing
Success!!! That is correct sir. the blue flashing letters is the kernel being installed.
Excellent!! Thanks man ...is there any way to check your phone and see what kernel you have installed, like the one I flashed? Other than the settings>about phone screen b/c I think thats been the same since I went to froyo
downloading now. Another great thing from Adrynalyne!
