[ROM][BETA] Quattrimus ICS
varockchick
53
4
What is the difference between cm9 and aokp? I'm wanting to try something different...my battery life sucks and I'm running advance task killer...still 50% battery drain in a few hours
inceyet
393
121
anyone running aokp care to try a new modded build.prop?...
(nandroid beforehand)<--- in case you dont like it for whatever reason...
https://www.dropbox.com/s/rdk73aicug6134e/build.prop
feedback is appreciated... :)
-attached a list of added/adjusted lines/values from the 0715aokp nightly...
found here:
Geek Yogi ? Android - build.prop tweaks (Root Only)
So do I just flash this on top or by its self or put the build prop in myself. Plz excuse that noob question but if I'm gonna get knee deep into the dev community which I do I need to learn as much as possible. Thank s
Sent from my VM670 using Android Central Forums
nitestalkr
889
261
Even aosp? I think its a bunch of crap anyways.
Sent from my VM670 using Tapatalk
All ICS roms.. some devs do take the risk and include gapps, and often Google doesn't do anything about it, but there's always that small chance where Google will take action.
sent from my un-dead sammich
Reactions: sellers86
nitestalkr
889
261
If its a flash able zip, then you flash over your current rom. Always back up before you flash.
Reactions: inceyet
clodfelterac
Samurai Dev
Jan 3, 2012
729
206
replace the original... added directions to post...
dingermtb
203
26
found here:
* goes in system/ (in place of original)
* rename original .bak (in case you want to go back to the original and you didnt make a nandroid)
Gonna try when i wake up. I'll report back. BTW, love your build props, ao i'm sure this will be just as awesome: )
Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
Reactions: clodfelterac
sellersj27
94
11
Es file explorer won't let me change anything system related... .it has root access checked, I just can't modify... any ideas?
Edit: got it! Trying now
sellersj27
94
11
So far so good. Seems a lot faster, though I did wipe cache/dalvik. I almost can't tell that my data was throttled last week!
cbucz24
195
38
Another thought I had was to make hybrid roms.
The only differences in roms between the thunderc models are:
boot.img
system.prop
Mms.apk
If I can pack up all versions of each of these and create a script to install the appropriate file set at install time, that would reduce the traffic by almost 2/3.
And if I can find a way to build template versions of these and replace the values after the build, that would reduce the build time by almost 2/3.
Here's a way to make one build tdm.
http://forum.xda-developers.com/showthread.php?t=1461712
Its called aroma installer. I'm thinking this is what your wanting to do.
varockchick
53
4
To all those Netflix people out there, I might have found a solutuion! I'm going to test it out tonight, but I'm fairly certain it'll work WITHOUT HARDWARE ACCELERATION. :D
If you can figure out how to get it working you'd be my bestest friend lol..even on PC it is soooo out of sync...drives me nuts...considering canceling my Netflix account
andrewnelson23
795
145
Well the fix is mainly just to get the picture working. On ics, hardware acceleration doesn't work. So, while trying Netflix, you can get audio, but no picture. My fix is to show the picture and play the audio without hardware acceleration.
I'm not sure about the syncing picture and audio, I don't know how good it'll be. I guess we'll see! I don't think it'll be too bad.
Reactions: nitestalkr
dingermtb
203
26
Gonna try it now. I'm in the same boat. Throttled last week, lol.
Non
