varockchick
What is the difference between cm9 and aokp? I'm wanting to try something different...my battery life sucks and I'm running advance task killer...still 50% battery drain in a few hours
Ooooh I like unicorns..lol....imma try it...aokp has more customization options... and unicorns... ;-)
anyone running aokp care to try a new modded build.prop?...
(nandroid beforehand)<--- in case you dont like it for whatever reason...
https://www.dropbox.com/s/rdk73aicug6134e/build.prop
feedback is appreciated...
-attached a list of added/adjusted lines/values from the 0715aokp nightly...
found here:
Geek Yogi ? Android - build.prop tweaks (Root Only)
Worse comes to worse I just re-flash
Do I need to install gapps with the aokp?
Yes, with all ics roms. The google legal department won't let us include it.
Even aosp? I think its a bunch of crap anyways.
Sent from my VM670 using Tapatalk
So do I just flash this on top or by its self or put the build prop in myself. Plz excuse that noob question but if I'm gonna get knee deep into the dev community which I do I need to learn as much as possible. Thank s
Sent from my VM670 using Android Central Forums
found here:
* goes in system/ (in place of original)
* rename original .bak (in case you want to go back to the original and you didnt make a nandroid)
Gonna try when i wake up. I'll report back. BTW, love your build props, ao i'm sure this will be just as awesome: )
Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
Another thought I had was to make hybrid roms.
The only differences in roms between the thunderc models are:
boot.img
system.prop
Mms.apk
If I can pack up all versions of each of these and create a script to install the appropriate file set at install time, that would reduce the traffic by almost 2/3.
And if I can find a way to build template versions of these and replace the values after the build, that would reduce the build time by almost 2/3.
To all those Netflix people out there, I might have found a solutuion! I'm going to test it out tonight, but I'm fairly certain it'll work WITHOUT HARDWARE ACCELERATION.
If you can figure out how to get it working you'd be my bestest friend lol..even on PC it is soooo out of sync...drives me nuts...considering canceling my Netflix account
So far so good. Seems a lot faster, though I did wipe cache/dalvik. I almost can't tell that my data was throttled last week!
