Kolma
I think he means https://forums.androidcentral.com/e...hone.app2sd&feature=nav_result&token=L2V8j6rINo, you can not use *ANY* a2sd type apps, TDM built in an app2ext that takes care of that need, and it will conflict with any a2sd app you download.
It is mentioned in the OP.
Which doesnt use ext partition, it just moves apps to the SD the same way you can in the built in app settings
A nice app, but pointless in ICS and later because it(ICS) now actually shows how much space an app takes up internally and on SD and will seperate the apps from the rest of the list if they can be transfered to SD.
