Slower speeds with Unlocked ver. on T-Mobile?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,586
6,171
113
It might be because carrier firmware have the carrier aggression. You can can flash to carrier firmware if you choose so.
yhboy
Active member
Aug 22, 2019
25
I was thinking the same, except it does show LTE+ which means it 'should' be using/taking advantage of carrier aggregation. Maybe it just doesn't play well with T-Mo network without their firmware?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,586
6,171
113
I was thinking the same, except it does show LTE+ which means it 'should' support carrier aggregation. Maybe it just doesn't play well with T-Mo network without their firmware?
I've messed around with this on my note 9 going from unlocked to carrier firmware and carrier firmware is better signal wise and RCS features but I love the unlocked version enough to not keep me on carrier one.
yhboy
Active member
Aug 22, 2019
25
Any particular reason aside from it being unlocked and having slightly less bloat?
CKwik240
738
18
My signal strength is lower than my S10+ (locked) was.
Not how are you measuring that? I noticed on the past that t-mobile branded versions of hardware would scale the signal meter differently than the unlocked version. But if I looked at the numerical value, the signal strength was identical.
shook187
548
57
28
Exactly.. T-Mobile always boost their signal on their branded phone compared to their unlocks counterparts even though the APN settings are the same.. I had situations where my wife's T-Mobile phone shows full signal even though there is no signal.
Lepa79
2,683
I have pixel 3 xl on T-Mobile and don't see any speed issues. If note 10+ unlocked is different for some reason, it will be going back. Don't have patience for things like this.
yhboy
Active member
Aug 22, 2019
25
Depending on ur location tmobile was having network issues yesterday, not sure if they still are
I read about that. But that doesn't explain it. I just spoke to a buddy who purchased an unlocked 10+ from Samsung and was experiencing a similar issue with reception. He flashed the T-Mo firmware on it and is seeing noticeably better signal/speeds (unrelated to the artificially boosted signal icon up top).
bhatech
Trusted Member
Nov 21, 2012
7,850
488
83
Don't go by the signal indicators, in my testing perviously at least in my location there wasn't any difference in actual speeds between the unlocked and carrier versions when I was with T-Mobile. Carriers like to show more bars in their firmware maybe but actual speeds and connection no difference. If carrier bloat and carrier firmware doesn't bother you then yeah just for your peace of mind flashing the carrier firmware to make it carrier version doesn't hurt. Personally always prefer the non carrier firmware but that's just me.
PS: if you aren't familiar flashing, then be careful and don't brick your device
tress
