Jeff Wolf
I am having the same issue but it just started a day ago and I have not added or changed anything on my phone. Any help would be great
Unfortunately it's a time bomb Jeff. It comes unexpectedly and noone knows the reason. Worst of all is that Samsung does not publicly acknowledge the problem so they do nothing to fix it. Hopefully they will quietly bring in the cure with the 4.4.2 update...though I wouldn't hold my breath. Meanwhile try if anything in this forum works for you. If you are rooted maybe flashing 4.3 again will help, (that worked for me). But any odd app or whatever could bring it up again.I am having the same issue but it just started a day ago and I have not added or changed anything on my phone. Any help would be great
I had the same issue.I got the same problem someone find a solution!
Alright. Check what apps you have installed recently. More than likely an app has triggered a chain of reactions that led to your battery draining. Uninstall the last few if you cannot pinpoint one. Note that no battery monitor app is likely to show the rogue app due to many factors conspiring together to lead to the battery drain. In my case it was Automatic Call Recorder and it never showed anywhere as problematic. That is the nerve racking part of this sort of drainage. Also if you are streaming music in eg your car stereo from your phone via bluetooth, that could be another trigger. Understand that what I write here is from experience, not from IT knowledge or degrees. They could work for you or not. Even IT experts throw their hands in the air since this problem appeared. After uninstalling switch off your phone and start it again. Hopefully the drain will have stopped. If not try a factory reset. It's painful but it may work.My battery was drained last night 30% in 8.5hours. I updated official 4.3 jellybean months ago but battery drain started just few days ago.
Which one?This repair battery app has helped mine. I don't know what it did but at 5 hours unplugged I'm at 89% instead of my regular 60 or so by now.
I tried Lookout once. It killed my battery. I uninstalled immediately. Maybe that was just my phone but try to uninstall and use Advanced Mobile Care instead. Then restart your device. See if it does any difference.Same problem here after a recent upgrade.
My phone use to last me all day, now its out of juice by 7pm. Same utilization as before and same apps as before. Biggest reported consumer after the screen is usually Android System or Google Play Services, sometimes my antivirus app (Lookout).
Really disappointing.
