LegalAmerican
Everyone's n7 lags. It'd just most ppl don't understand or even know what lag is. Every review from pocketnow to smaller reviews like flossy Carter all there note have lagged. Like I said earlier it's a nice phone that looks amazing but if your not use to Samsung's laggy setup it will drive you nuts. If you are a Samsung user it won't bother you one bit. A for sure buy if you have used Samsung. If not test it out on some 14 day plan. I loved the phone just couldn't handle the lag
I went from a Galaxy S3 (two of them, the first white and the second Pebble Blue) to the Nexus 5 and then to the Note 4. I noticed some lag on my Note 4, and a little on my S3. But now with the Note 7, I haven't had ANYTHING compared to the Note 4 or S3. So i'm not really buying that the lag is a "big problem" in any way. As I mentioned earlier, i've had one or two hiccups with things and that's been it in a week.
Even my Nexus 5 had some lag at times, so it's not even just Samsung. I've used iPhones before that have lagged as well. Specifically the iPhone 4s, but even as recently as the 6s+. I feel terrible for Flossy Carter that he had some lag on his Note 7, but luckily I haven't had the same issues. And that doesn't mean I don't know what lag is.
