What do you mean?Your at 45% left with that specs in device care?
Signal is mostly 1 or 2 bars when I'm at homeYour w wireless signal looks really poor. I see only 1 bar. What is the signal strength in dBm?
Poor signal is going to drain the battery.
Device care shows 16 hours and you have 45% left?What do you mean?
Looks like WiFi calling enableYour w wireless signal looks really poor. I see only 1 bar. What is the signal strength in dBm?
For dBm go to settings, status information, SIM card status. View attachment 345193Signal is mostly 1 or 2 bars when I'm at home
I've had this phone since it launchedBattery life is pretty garbage so far for me on this device. 3.5 hours of SOT with 36% battery left is just plain sad.
Hoping that after it does the whole learn your usage it gets better. Really want to use this phone and enjoy what it can offer. Not worth it when the cost is to always carry a charger or battery bank on a 2022 phone
Nope had it since it launchedDid you just get the phone? It will take a few weeks for the battery to adjust to your usage -- and setting things up will take a toll.
How long have you had this phone? Is it just learning your usage cycle?What do you mean?
Yeah on my Ultra I'm getting 1 day 4 hours with 9 sot from 100% to 5 %I just got 1 day 7 hours, and 7 hrs 30 minutes SOT with my regular S22 its possible to get more battery life though you may have do throttle a few things down and turn some stuff off when you're not using it.
