I am waiting for my S7 Edge to arrive. I was wondering, should I make an initial 12 hour battery charge before first using the phone or it is fine start using it right away?
Thank you.
Thank you.
I usually start using the phone pretty much right away but it's probably a good idea to have it plugged in while its doing all the uploading of apps and related things usually the phones will arrive about 50% chargedI am waiting for my S7 Edge to arrive. I was wondering, should I make an initial 12 hour battery charge before first using the phone or it is fine start using it right away?
Thank you.
No need for 12 hours.. It should charge up within 1 to 2 hours tops.So, a long 12-hour charge or a normal full charge after the battery has been drained out for the 1st time?
