The screen still looks vibrant and beautiful, and I seemed to have added 2 hours on screen time to my battery life. This is awesome!
Yeah, I've switched mine to 720p and I still like the way it looks. My battery life is so much better!The screen still looks vibrant and beautiful, and I seemed to have added 2 hours on screen time to my battery life. This is awesome!
Shouldn't have to downgrade your phone's best capabilities to preserve battery life.
When I tested the QHD vs FHD, I noticed zero difference in battery life
I will say to the naked eye you can't tell the difference, but changing it to 720p is downright silly.Except its not a downgrade. Plenty of 1080p phones have gorgeous screens, and this one is no different. And I didn't have to do it. I chose to. The added screen time was surprisingly and welcome.
See and I saw zero difference in screen time.
Settings and then display. Within there you should see the option.How do you change resolution
You have to be on Nougat.I dont have an option to change resolution. Hmm
I mostly look at text on my phone, I can't tell a big enough difference to stay on 2k. I'm on the nougat beta and can't use my gear vr until I'm on official because Verizon stopped the beta so I have nothing to make me use a higher screen resolution. As long as you use the smallest DPI settings, you can continue to see everything on the screen.I will say to the naked eye you can't tell the difference, but changing it to 720p is downright silly.
Now you know why I get amazing battery life on my 7 Plus! I'd rather have 1080p resolution and amazing battery life than 2K and so-so battery life.
Exactly.Shouldn't have to downgrade your phone's best capabilities to preserve battery life.
I get amazing battery life on WQHD in my S7 Edge, over 6h SOT consistently.Now you know why I get amazing battery life on my 7 Plus! I'd rather have 1080p resolution and amazing battery life than 2K and so-so battery life.
Exactly.
It makes zero difference, the Estimate is useless as it's all down to how you use the phone that day.
Mine is set to WQHD. Why downgrade my display to get no benefit?
I also noticed that in 1080P text in apps like WhatsApp look a bit jagged and thick, not smooth as they are in WQHD.
