[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
Maldito.boss
12
It works for me ive played music and used astro to delete files.
WHAT should I do I mean I always do a clean back up but nothing of my files ...... I still can play music with Pandora but can't live without my new gf prego pictures that I took this morning
beezy
2,434
1,010
-try wiping cache and dalvik
-or full wipe flash again :'(
Other then that a adb logcat but that will probably just lead to a full wipe.
jwhood
5
Hey beezy can u lend a dev sum advice
I know its off topic a dev over at xda named revelation is trying too get this to work for the mt4g,but it wont get past splash screen here is the link............. http://forum.xda-developers.com/showthread.php?t=1318259
beezy
2,434
1,010
thats what i figured. both are a no go.
Check and see if its getting a IP address.
If it's not then you are seeing what happen to me and i wasn't able to trouble shoot it,everything seemed to work how it should. Then it just out of the blue worked.Also try wiping cache. If it doesn't work and i get a update up and then still doesn't we'll get together and pull a log to see if its showing different then all the logs i already looked at.
That's why the update took so long yesterday wifi didn't work then it did.lol
adamw1101
16
yeah my wifo has been working solid. As for that app draw issue the activity manager crashed and reloaded wiping my apps again I think its not saving the apps in its memory or something
Sent from my Nexus S 4G using Tapatalk
Tomgombosi
8
It says obtaining ip address then says connected then about 3 seconds later it disconnects. I actually just tried a fresh install and same results.
hooperb63
Active member
Oct 21, 2011
43
5
does anyone know if there is any plans to release beta3 in the next couple of hours 00.25am here i uk dont wanna wait up if there i no point. may aswell wait till the morning!!! thanks.
Status
RandyRoyalty
