mouseglider
thats the OEM battery. Never trust specs on the web.
Thanks very much - this IS a Sprint Nexus S correct?
If this is so, than the Sprint Samsung Moment battery IS the same even if you never had a Samsung Moment. I say this, because if you buy the battery by searching a Sprint Nexus S, the cost is around $35'ish, but if you buy it for a Samsung Moment, it cost about $10'ish - same exact part number - this will be Great!
