1.13.604 Update -- Discuss Here (Read Post #1 First)
Not sure if anybody mentioned this yet but the font rendering while browsing seemed to have improved. I need to test this some more but they definitely seem more uniform when zooming.
Everyones time unplugged change when they updated? I'm going on 6 hours and it reset when I updated.
Under battery manager, use
Artifacts have been introduced into the camera/video recorder. Should be at least a green and a red stuck pixel on the bottom half of the applications. Dunno if they show on things you've recorded though.
no issues so far.. upgraded 2 phones.
takes a few minutes to download (wifi)
and several minutes to boot up.
if you are on the red eye for a while. just leave it.. could take 5+ minutes just sitting on that screen.
edit : no bad pixels in my camera, must just be yours
Wifi connectivity issue is still there... yay. What a pain in the ***. Not noticing anything different so far. But i am dissapointed the wifi isn't fixed. The loading definately takes longer also when booting the phone up.
Okay guys updated phone and hit a button on accident and got the update status when it was done it left me in recovery waiting for me to reboot check out pics
Any ideas if this can help root... I did hit install update when I thought I had reboot selected and it said no update file found
Sent from my DROIDX using Tapatalk
So far all this update has done is improve font on the browser and add "dead" pixels to the camera app. All the other changes they promised either aren't there or haven't been noticed yet. Somewhat disappointed so far. But coming from Blackberry i am used to the disappointment after an update.
Everything seems the same. WiFi is still an issue. Sometimes i stay connected. Sometimes i dont. I hope Froyo fixes this. The battery issue does seem to be fixed. After the update i kept the screen on for almost a full 2 hours messing with wifi settings(with no luck) and the battery only dropped 10%. Seems like an improvement to me. Oh and the My Verizon update also worked.
there are a few places where wifi settings are affected.
1) you can tell it how soon to turn off wifi (for example when the screen shuts off) it will turn the wifi off
2) your battery profile, based on settings. it will disable depending on what is set.
3) could just be your AP, sometimes, diff. chipsets don't talk well.
Well I didn't see any cosmetic changes on my update, but w/e it was worth updating it at the same time as my cousins and watching his SMOKE mine in download speeds, i have too many widgets running lol.
Well Im late to the party but Ive upgraded & like most havent noticed much of a difference. One strange thing though is when I goof up on my pattern lock it says "sorry try again" I dont remember seeing that before.
still no LED for charging status...
I have led light while charging... its red right now, not sure if it stays on the whole time or just when the battery is really low (mines at 5% - in the red).
Other than that i haven't noticed anything exciting... i never had issues with wifi or anything so i can't speak on that.
Just received my ota update! Anyone else?
Unfortunately my son had to go to the hospital so i was up and tinkering with my phone at 530 am. I checked for updates and there the update popped up. Total time downloading and installing was about 5-8 minutes which isn't bad considering i did this update over 3g in a hospital with notoriously bad connections. One thing i noticed was before the update i was down on one battery bar barely any use. After full bar! Guess that bugs. Fixed.
Checked mine this morning and it was available. i haven't had any issues before so we shall see how it goes.
gruptysh
