[6.25.11][ROM] BAMF Sense 3.0 GB RC3
I misread the posts. I was thinking you were the one with no data connection. lol. Haven't had any problems with messaging tones so not sure there.
I'm not having any issues with the messaging tones either and did a quick search over at XDA and didn't see anyone else reporting that problem. The was one individual who had issue receiving messages and a few wipes seem to fix his issues. Only thing I can think of trying is a wipe or maybe even re downloading it a flashing all over. Hope you find a solution because this a great Rom.
This is the first time I've heard of this issue as well, maybe a bad flash or something along those lines. I would try using a different messaging app and/or try messing with the notification settings with a new app
i'm using Chomp SMS but it uses the settings in messages to dictate tone and such. i'll try removing it and see what happens
well that was odd, its clearly installed on my phone but doesnt show in market under "my apps" and i know thats where i originally downloaded it, not sre if i recovered it using titanium or if it just came in with my other apps after setting up phone after flash, well i chose install and installed over it see what happens
edit: well that changed nothing so back to uninstalling chomp idea and see what happens with just stock messages
edit 2: ha well that works fine now for some reason lol, ok now to see if i can reinstall chomp and see if what happens
ah ha its fixed, think however they updated chomp through me off, when i first installed it, while i had to turn off notifications of default messaging app to not get double notifications it used the tone set in the messages app settings, now you choose the tone in chomps settings itself that through me off i dunno y i assumed that couldnt of been a change in a update to the app and was something so simple lol, though the funny thing is the song it was playing before was in no way selected in settings but who cares its working perfect now :)
Love the rom, but a few of my apps keep force closing. Especially windows messenger video! Its driving me crazy.
I have had a few apps do the same on an earlier version most would work after clearing data and if that doesn't work remove the app from phone and try downloading again. Most of the apps that required to be downloaded again were restored from TB w/out data.
You can make a nandroid backup, then run fix permissions in the bamf toolkit - this may solve some of the FC's.
Yes, I was wondering this too. I usually sit around 17-22 mgs, now I'm lucky if I hit 5 mgs... And yes, this is since the day I installed GB... (I run tests 2 or 3 times a day, and each time I run it like 4 times just to make sure... I'm bored a lot... ;) )
new problem lol, my battery is draining like crazy, i went through set it up just how i had before and my battery was typically at 55% when i got outta work now its like 10% thats a huge difference any idea why this would happen when all my settings and everything are same as before i flashed this ROM?
Could be the quality of the signal you got today - weak signals will lead to battery drain.
Or maybe you should try a different kernel out.
What are your SetCPU settings at? If you're using a lean kernel, are you on the speedtweak script?
setcpu settings are
screen off 368 max 245 min
charging 1408 max 368 min
battery <22% 768 max 368 min
on main screen in set cpu it says 768 max 368 min in green font
on the min max bars below that max is 1408000 min 368640
i am using imoseyon_leanKernel_v3.3.6GBtest i've never messed with any speedtweak script
Downloaded it last night after using BAMF 2.1 for a few days... I installed it and was back up and running with everything in about 2 hours... NICE!!!
setcpu settings are
Those settings look fine, maybe try a different kernel. I've been using the dream kernel that came with it with min at 368 Max 140800 on demand governor & I get great battery life. Try imo's latest I think its 3.3.8 or the latest dream kernel & only use min & Max with no profiles
Sent from my ADR6400L using Tapatalk
