Active Notifications
Johnly
Retired Moderator
Oct 6, 2010
4,916
319
With the Note 3 set like that...does hitting the home button open the phone...since there is no swiping needed? Seems like the phone me be turned completely awake many times accidently.
There is a option to use or not use the home button for that in dynamic notifications. I set dynamic notifications as my lock screen and haven't had any unlocking issues yet.
Sent from my SM-N900V using Tapatalk
Bobbman
227
Thanks! How is it on battery?
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Oh that is with the paid version. Doesn't appear to work at all on my note 3 with the free version.
Texts and things just go straight to my Samsung home screen. Was hoping to test it out before actually purchasing.
Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
I read some were having problems, but that enabling it as lock screen fixed it.
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
Johnly
Retired Moderator
Oct 6, 2010
4,916
319
That is it. Make sure stock OS is set to no lock screen and enable DN as lockscreen. Breathing notifications work great and don't go off when you don't want them to as in your pocket!
icnmayhem
295
is there an option to have the notifications appear when you pick the phone up? or just stay on constantly, since they shouldnt use much power on a black screen?
ioannisgk
Active member
Oct 9, 2013
28
Can someone please post a guide on how to enable dashclock widgets on DN?
I have successfully installed Dashclock widget with some extensions that work fine.
But when i enable them from the*DynamicNotifications settings, they do not appear on my lockscreen.
Can you please help me?
I have paid for the premium features and i can not get this to work.
Everything else is fine.
Thank you.
Sent from my SM-N9005
Lanhoj
1,358
49
Can someone please post a guide on how to enable dashclock widgets on DN?...
1) Uninstall Dynamic Notifications
2) Install DashClock
3) Reinstall Dynamic Notifications (DashClock needs to have been installed BEFORE Dynamic Notifications)
4) Assign separate Extensions for DashClock & Dynamic Notifications - Extensions don't work well if you have multiple instances of them (for example I have 2 battery & 2 weather Extensions - 1 for each)
ioannisgk
Active member
Oct 9, 2013
28
This worked. Thank you! Can you recommend some dashclock extensions that you use?
Lanhoj
1,358
49
...Can you recommend some dashclock extensions that you use?
DashNotifier is my favorite Extension but that's better suited for DashClock itself.
On Dynamic Notifications I only put a battery & weather Extension.
Also, I use "Better DashClock" instead of the "Official" DashClock as it has more customization options.
ukfred
