Bluetooth Issues
Switched to super_frankenclean_2_8nv_final and everything seems to be working. Flashed using RED CWM. I tried orange CWM but it didn't work.
Tried to load 2.9nv but it didn't work last night and 2.8 is working so i'll probably just stick with it for awhile.
Hope this helps,
cheers
Switched to the ROM below and everything seems to be working. Flashed using RED CWM. I tried orange CWM but it didn't work.
Original Link at XDA
2.8
Nonvoodoo
super_frankenclean_2_8nv_final.zip
Hope this helps,
cheers
You do realize Adrynalyne started the exact same thread, word for word here at AC http://forum.androidcentral.com/ver...om-superclean-2-9-1-ea15-eb01-eb16-based.html
No need to link to XDA, it is right here.
And you can't use orange cwm. Orange no workie right now.
Finally got my bluetooth working. I used Odin to go back to stock and then checked my bluetooth and it was working. I then used Odin again and loaded EB16SC29. Checked bluetooth and it was not working again. So I used Odin yet again to flash ebo1modem. Checked bluetooth, not working. Used clockwork to load eb16_voodoo_working, enabled lag fix, rebooted. Not working yet. Back to clockwork, loaded nuance_froyo.zip, rebooted and I have working bluetooth again.:-) Links for everything I did are in the stickies, so I won't repeat them.
jjassa1
