Cyanogen 6.0.0
hello all......so here i am running this rom (cm6 6.0.0) and everything is running smooth.
i notice that when ever the phone goes to roaming the phone looses data transfer and when ever i tried to make a phone call it tells me i am on the Verizon network and i have an unauthorized devise.
i have tried the nightly releases but its the same problem....
has any one had this problem ?????????
You have to flash back to a sense rom and do it.
If you don't mind, can you tell me the correct way to do this? I know that I need to do a nandroid backup, but after that, do I wipe, install the new sense update, and then go back to nandroid and restore Cyanogen?
What recovery are you running? RA or clockworkmod? I ask this because I prefer using clockwork, but could'nt get the PRI to update until I changed to RA recovery. I had tried about six times with clockwork with no success. I changed to RA through the Rom Manager app and was able to update the PRI after the second try. So first make sure to make a nand backup before you do anything.Then make sure you have the latest baseband zip file downloaded and ready to go on your SD card as well as the AC rom zip from the sticky above. Now if you have RA already installed go ahead with the following steps, if not then install RA recovery first and proceed. 1)Wipe. 2)install the radio/baseband file. 3)Install the AC-rom file and once that is done reboot the phone. Now go to phone info and make sure the baseband has been updated. 4) Follow the steps in post #3 of this thread ->http://forum.androidcentral.com/htc-evo-4g-roms-hacks/31375-pri-update t.html .Be patient cuz it might take a few tries but it will eventually go through, just make sure to keep checking the phone info after every attempt to see if the PRI has updated. 5) Once your PRI updates, you are done. The updates will stick when you go back to your saved cyanogen backup even though you wont be able to see the PRI info, but you will be able to tell from the updated PRL which should be 60670,Baseband 2.15.00.07.28 and the PRI I believe is 1.4something :p
Ok so I am running Cyanogen do a nand backup and go back to Baked Snack for a while I get bored with it and come back to the dark side but when I do Rom Manager alerts me that my Rom has a new update so I update to 6.0.0 but when I get everything loaded there is no market place app so I can't download any of my apps. What gives?
Download and flash the google apps. Search first buddy guy.
Two questions.
1. Is there a better way to copy and paste? On the browser I mean. I know you can just press menu-more-select text, but its really cumbersome.
2. I like watching justin.tv on my phone. Doing this wasn't a problem with fresh rom, but now I get an error saying my device isn't compatible with the site. Is there a way to get justin.tv working? Thanks
Found a new Theme Im going to try out... anyone wanna join me in this???
---> :cool:
Ok, question. So I tried to make a Qik call today and, no matter who initiated the call, I couldn't hear the person on the other end. I could be heard just fine. Anyone else having this issue?
I tried this rom and I liked everything about it except for the camera app. Is there any way to revert back to the stock one. Also I can't tell if its 720p when I play a recorded video.
Can someone give me the benefits of this ROM? I have a great 4G signal in my area and would hate to give that up.
MightyExecutor
