Download the Official Droid X 2.3.340 OTA Here
Help!
Use the computer or get astro file manager from the market and move it.
I tired this but the option to move the file to the ROOT folder is not working? Gives me no option to paste or move the file once i get to the ROOT folder. Any suggestions?
So... this sounds like a dumb question but how do i move/copy the file to my sd card? i longpressed on it and hit copy but cant find out how to choose my sd card... HELP!!!
You need Astrofile manager or an App that lets you navigate your phone files.
Update installed and was able to root with Z4 afterward. So far, so good and all of my superuser access was granted. Running stock ROM and overclocked to 1.2ghz.
i have astro. but not sure where i need to move the file to.
Same place I'm trying to move it to -the root folder. Its not working...if you hit up until you see the Root folder its there but no way to move it??? Anybody know a way?
I had a bad DL and received the "could not verify signature" error. I deleted it and downloaded from the link on page four and it went flawlessly.
To answer above, once you find the update.zip, you must long press it to get "edit" - "move", then navigate to sdcard, then you will see a "paste" command. Select that. Its located on the top bar of astro.
Paste into which folder? /Root folder...if so there is no option to do this.
There is no folder named root. Root just means the highest level of the SD card, aka not in a folder. Just paste it in with all the other crap in your SD card and some how it finds it, as long as it isn't in another folder other than the Root (highest level) of the SD card.
Reactions: papadonna
There is no folder named root. Root just means the highest level of the SD card, aka not in a folder. Just paste it in with all the other crap in your SD card and some how it finds it.
Gotcha!
It works now once I took it out of the download folder on the sdcard.
when i download it shows up in my sd card downloads. do i need to do anything elseto move it?
The update.zip should have been hosted within minutes of it being DL. We need to be a bit more prepared next time to get it out quicker. Thanks OP. Why wouldn't Moto or Verizon just host a file? Afraid of instructing people to boot into recovery? We aren't children and this is my phone!
if im in astro i go to download choose copy and paste it into acct? that is the higest folder.
Keep going up till you see SD card. Select SD card then hit paste.
You want /SDCard/update.zip
Not /SDcard/acct/update.zip
Or /SDcard/Android/update.zip
Reactions: LdotAdot13
I still can't get through to any of these links...sux. I'm just gonna wait for the update to get pushed to my phone. Shouldn't be too much longer...I hope.
Page four has a link with several links attached....if that didnt work your guess is as good as mine!
I got my copies off link on page 4 ;) , I snagged a couple of copies :p
francomattia
