ARCHIVED: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2011)
Status
Not open for further replies.
Re: Drew's CM7 builds (stable: 08/02/2011 | experimental: 08/03/2
okay so wireless bluetooth headsets work in call? holy s! thanks drew!
Flashed the ex 4 and I don't get it? Every version is better than the next.
sent from my Cyanogen Optimus
I can verify Bluetooth works, I used it all day with my music and in the car which connects to The Sync system automaticly. I have 3 bluetooth devices connected to phone and all 3 connect and work recieving and send calls.:)
Now, I do have one issue and that is with the hotspot setting. I'm not sure why, but it doesn't seem to work. In reborn, I could never get consistent connections, but in this I'm not able to get any connection. Is this a hotspot problem and does anybody know a fix?
how can i get ota updates?
Do you realize that you put a button on my phone and told me NOT to push it? Do you know what that does to me? It's like that Tiny Toons where they are in the elevator and the duck is saying I want to push the button, my turn.........
So, what time tomorrow can I push the button? hehe
Dude I was raised on tiny toons lull!
Sent from my LG-LS670 using Tapatalk
How come my cm7 updater is not picking anything. Up its not working
just flashed my optimus, it works perfect and really fast, better than froyo
only 1 issue, the voice dialer button doesn't work, it does nothing no matter how long I press it.
I tried to change the key binding file, no luck. Does anyone have the same issue?
Thanks.
Thanks.
I am aware of this issue and a fix should be provided in the next experimental build which will be available less than 24 hours from the time of this post.
Thank you very very much.:D
one more question, can I do a dirty flash with new rom to fix this issue? I really don't want to reload all my apps again:-$
Flashed Stable 08/02/11, and getting amazing battery life with wifi on and with 3G on. Great job on that Drew.
Sorry if I missed this being duscussed, but the wifi sleep policy of the latest stable (8/2/11) doesn't seem to work. When set to never it still turns off when the screen goes off.
Great ROM though. Thanks for the awesome work.
So the cm7 updater in the unstable build excites me. Proving drew's bad assedness even more. Just wondering if there is a URL for the theme updater? Could be super neato :D
Never mind figured it out there's an update theme server button In the settings. Rock!
Food for Thought...
I am not sure if this is native Gingerbread functionality or CM functionality, but there is the ability to select and/or create Profiles, which lets you set audio levels for various applications, including but not limited to your phone's ringtone. I was wondering, in a developer's perspective can this component be easily customized. What if you can set Bluetooth, WiFi, Data Sync, 3G, Airplane Mode, Brightness to a Profile. You know the same things you can set on the power widget.
This is how I would use it...
  1. I am at home, I have wifi, I can set my Home Profile to turn on WiFi to help conserve battery instead of using 3g.
  2. I am at home, its nighttime and I ready for bed. I switch to my Sleep Profile which turns on Airplane mode to help conserve a whole lot of battery.
  3. I am driving to work, I switch to my Commute Profile which turns on Bluetooth, sets media volume to high and sets my brightness to full
  4. I am at work, I switch to my Work Profile which turns on WiFi and sets ringer volume to vibrate
Alright, you get my point. I think this would add a great deal of customization on functionality that already exists. Not to mention, I would probably use Profiles a whole lot more. Let me rephrase that, I would probably start using Profiles.
Is this even be possible? Any thoughts?
Would this type of request go to the CM team to have it part of their base package or would be up to Drew to incorporate it in his ROM.
Status
ahsokacat
