ARCHIVED: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2011)
Status
Not open for further replies.
Has anyone been able to update with data2ext without losing all the apps? I tried to flash stable 2 over stable 1 (wiped cache and dalvik), but after flashing stable and gapps, booting into the ROM, flashing the data2ext in recovery, booting in to the ROM again and enabling data2ext, then rebooting, none of my apps show up, just the default set... yet data2ext is running, because it shows the correct free space.
Just wondering if anyone has experience yet with that so I don't have to clean wipe every time and restore apps via titanium.
Just wondering if anyone has experience yet with that so I don't have to clean wipe every time and restore apps via titanium.[/QUOT
you can dirty flash just don't forget to apply. Gapps and data2ext the enable ext ......then titanium Backup your apps
Sent from my LG-LS670 using Tapatalk
Reactions: srthimsen
Re: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2
i installed 002 over my stable 001 which had data2ext. once i flashed the data2ext back all my apps stayed.
You can use this and it will move everything to SD but uses internal memory for the little bit of cache... Doesn't cause market errors like data2ext eventually does...
Just flash it. No configuring required (assuming you already have an ext4 partition): http://db.tt/u8I3UQu
Hey my market has been reverting. To the old one ....but I think its was metamorph
On the recent stable build I've now started to notice audio stuttering on all audio programs (I use Pandora and DI radio) every once in awhile along with severe lag occurring at the same time on the phone. I am not overclocked and have done 2 complete wipes and its still reoccurring. Happens on wireless and 3g. I also tried changing the dsp manager settings.
Yes I can confirm this I was just listing. To music and when it went to sleep it lag..
Quote -it the dspmanager that lags it doesn't have to do anything with the rom
Dude, no offence, but you need to learn how to quote correctly. If done right the person quoted should be high lighted or letter different color. Like shown in my quote.
sent from my CM7 gingerbread Optimus S
Always happy to help, hit that thanks button if I did
However, yours wasn't correct either. Oh the irony! I think it was because you quoted his misquote. Lmao
Reactions: manny29
Lmao!! Stable 002 had been running great thus far
Change the governor from "smartass" to one of the others. For some reason the smartass governor makes it skip like that when the phone sleeps.
It's under the CM7 settings menu, btw.
I have not experienced this. I was listening to Pandora for quite a while yesterday streaming through bluetooth headphones, screen off, I'm running setcpu with profiles. My screen off profile is using the ondemand governor 600 max, 122 min. No problems on the latest stable for me with these relatively meager settings.
...although, I don't know if it makes a difference, but I am using data2ext, with a class 10 sd card -- which is where Pandora resides.
It also strikes me that most music players (not sure about Pandora) cache music to the SD card, so if space is low, or your read/write speeds are low, you might potentially have lag issues.
I have not had any of these problems either. Did you try uninstalling and reinstalling Pandora.
I think this is a result of the smartass gov. It caps the Max CPU at 300 something while the screen is off and streaming audio doesn't like it. Try switching to a different gov while listening.
I just added that to my post I didn't want to make another post just to write something. When I can edit mine...lol thanks though .....
I did that if you turn off dSP manager in running apps you would see the difference when you put the phone to sleep it's not your CPU it the app that lags bro ...
DSP Manager has nothing to do with it. Pandora (and similar apps) simply don't like the CPU being underclocked. Though I personally have not experienced this on Google Music...
Status
Tiokujha
