Finally!! 6.0 OTA
Got mine today as well. I didn't do anything special, it just showed up. It's a Nexus 6 from Best Buy running with a Cricket sim (was on LMY48T, now MRA58K).
Posted via the Android Central App (Nexus 6)
Got mine as I woke up now. I'm on LMY48T.
Just got OTA 6.0 Notification on my Amazon Nexus 6 No sim My fi sim has shipped and should be here Friday.
Reading the OP's message, I too removed my AT&T SIM on the phone and restarted. Lo & Behold ... Marshmallow comes in!!!
I dont understand why it has to be so, since I didnt buy the phone through AT&T and nor is it locked to AT&T.
Edit - The phone failed to complete the OTA update. When I go to software Update section, it shows Marshmallow waiting to download. May take upto 45 mins
That doesn't sound ridiculous, at all.
But I tried it earlier morning and it produces no results. BIIIIG SURPRISE. HAVE YOUR LAUGHS GOOGLE, LAUGH IT UP CHUCKLES. I don't know what I'm even expecting from this update. It's not like it's going to overhaul the device.
This is not a sustainable relationship Google.
Re: Fyi 6.0 OTA on Nexus 6 available immediately after factory reset
a share of phones on the 5.1.1 builds that are in rollout mode are receiving the m ota daily.... No matter what they do.
I deleted my facebook app and got the ota. (not really)
no it is magic!!!!
Marshmallow first impressions
Now that the OTA seems to be on its way, I thought we could share our views about Marshmallow in one thread. So, what do you guys like or dislike in Marshmallow?
Likes
- New volume controls. Finally able to change notification volume while listening to music.
- Do not disturb automatic rules. I can now set DND automatically during the times I have classes.
- Being able to rearrange quick settings.
- New copy and paste buttons - the old ones were a bit confusing.
Can't comment on yet
- Battery life - too early to tell, I had M for 5 hours now.
- Now on tap - again, haven't had much chance to use it.
- App data saved in drive - it doesn't seem many apps are on board yet. Also, this is a bit of a hidden option in google drive settings. I think it should be in the main settings.
Dislikes
- That the phone lock-screen shortcut has been replaced by voice search. I use voice search even less than the phone function of my phone. Maybe I should give it a try.
Re: Marshmallow first impressions
I feel about the same as you do. The battery life though seems about the same when using it often. I haven't been able to test how doze helps yet.
Posted via the Nexus 6
Well compiled. Those seem the most obvious changes. I miss the phone shortcut since I used it quite a bit.
On tap is a good feature and I already used it productively.
Hopefully the doze feature will increase the battery life and that's something I'm looking forward to.
Hopefully there'll be more gems hidden in the system
Nexus 6 on Android 6
6.0 is really not that great. Battery life has only doubled. Boot up time has dropped from a minute, to 14 seconds which is probably due to the extra 2gb of ram its now showing.
I was also surprised to see that the back cover can now be removed exposing an SD card slot and a removable battery, but it fully charges now in 20 minutes so that's kind of a moot point. Oh yeah, the Iris scanner appears to be quicker than the FP scanner on my Nexus 6P but I've only had it for a couple of weeks and need to do further testing......
Is anyone else that is running on 6.0 having poorer battery life than they did on 5.1.1? I have tried everything, wiped data and cache, total reset started from scratch as a new device, hardly any apps downloaded and still my battery life was better on 5.1.1 than this.
SpinjamShopeepinjam
