Folder Problem
beasleybiz
21
I need a little help with a folder issue. I created a folder called Work Apps and was adding apps to it. I messed up and added the same app to it twice. Now when I try to delete one of them by long pressing and then push it to the trash can the phone flips back to the main home screen and sometimes randomly launches different apps. I guess I could ultimately delete the whole folder and start over I guess, but surely there is a way to remove an item from a folder.
beasleybiz
21
Ok, will do that then, thanks. I will also see if I can replicate the problem, if so I would consider that a bug that needs to be fixed, if not just some random fluke I guess. Thanks for the help.
yeezygaplogo
