[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
Ummm...so pretty much vzw should replace that ota poop they sent out with bamf forever 1.0.7 and send team bamf a check.
coming from bamf remix 1.8 do i need to dl from 1.0 or can i just dl 1.7? Also is it that much better that i would notice a significant difference. sorry still kinda new at this... oh and also whats all this talk about NFL moble? is it free? just wondering cus i m a huge football fan. Thanks!
I came from Das bamf sense 3.0 and forever absolutely blows it away. The gingerbread base is now the same as the ota but with less broken stuff and sense 3.0 thrown in. NFL mobile is free for 4g devices and is fully functional. You can skip directly to 1.0.7 as long as you have a compatible radio and do the proper wiping.
Reactions: Bakafish
whats a good radio to flash with forever? can i dl nfl moble off the market? why is it only free if you have 4g?
Thanks again!
just flashed forever 1.7 . LOVE IT ! freaking awesome!!! quick question: do i need to flash a radio even though my phone is working fine. i dl MR3 but not sure if i need too.
Couple of questions coming from 1.8.6
1) How do i find the BAMF extra folder? Not seeing it anywhere.
2) Do i have to delete my toolkit? (supposedly possible security reasons)
Any help would be greatly appreciated.
no, if you have the Mr3 radios you're fine.
If you don't have the extras folder on your SD card, don't worry about it. The toolkit will be gone after you wipe the phone before the Forever install. It's been replaced by BAMF settings.
Reactions: J-Dam
Thanks a ton, nate.
Sorry, I misread this the first time. I'm guessing you have the MR2 radios? (1.170.605.0, 1.39.00.0627r)
You can check by going into about phone under settings, then software info, more, then baseband
I'd recommend upgrading to the latest radios (MR3): 1.48.00.906w_1, 0.01.78.0906w_2
I flashed the 3g radio, now I need to do the LTE. My question is, do i need to delete the PG05IMG.zip which was the 3g flash? And if i do, do i just put in another PG05IMG.zip (LTE) one?
just to confirm, no need for data wipe for 1.0.7 coming from .6 right?
should i wipe cache and davlik at all?
It will wipe dalvik for you. You shouldn't need to wip[e, if you note what it says at the bottom about Mail.
Check changelog.
Yes and yes. Once everything is installed rename the last one as well so you don't get stuck installing every time you go to bootloader.
Sent from my Bolt via Tapatalk.
Ruhanis
