[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
Yes and yes. Once everything is installed rename the last one as well so you don't get stuck installing every time you go to bootloader.
Sent from my Bolt via Tapatalk.
thanks, just rename it to anything? sorry for the noob questions
Rename it to something you will remember... it's always a good idea to have these radio files on your SD card just in case you need to flash them again.
When I get off my lazy butt ;)
It sounds weird, but its been a really difficult bug to squash.
Take your time ;) Its just my luck its the one speed dial number I always use. Had to substitute my wife for #5 :)
Thanks for all your work and another great ROM Adr.. sending a donation soon.
Hi.
I just installed over 1.0.6 with 1.0.7 and now receive the following error.
The application email process com.htc.android.mail has stopped unexpectedly. please try again
I can not even delete the mail accounts i had configured anyone else had this happen or know what to do to solve it ?
Ok maybe if i read a bit more before i ask stupid questions did as told wipe data with titanium backup and now it is working
I tried to do 7 over 6 and it worked fine except for some reason it lost about 70 apps in my app drawer even though the market showed them as installed. Multiple reboots didnt fix it. Did the standard wiping of cache and delvik which also didnt fix it. Seemed to be all the apps I have on my SD card.
thanks, first time i've installed a custom ROM and this is awesome :)
I tried playing videos I've taken with my tbolt and none of them works. I can hear the sounds but the video is still
the lock ring mods over on xda dont work with this rom. Are there lock ring mods that anybody can point me to that do work?
I am currently running another rom (don't see it on the list, don't remember). Android 2.3.4 HTC Sense 2.1 and software 2.01.605.0. It is a Bamf sense I know, it says that when it boots.
So for someone who has only done this once. . .but wants improved stability, I like the look of this rom. I upgraded the radio? Do I need to do that again? before or after? The wipe button? Thats the delvik cache thingee? Where is that setting?
You MUST delete the BAMF_Extras folder under your sd card prior to installation
You MUST wipe on the first install, and possibly future versions of this rom
Download from the URL below
Copy to sd card
Reboot to recovery, and install from zip
DON'T FORGET TO WIPE!
Optional: Post your review
Download from the URL belowk
Copy to sd card
If you have a compatible GB radio, then you don't have to upgrade them. But, I would do just that. Here is the official MR3 GB radio from 2.11.605.3, 1.48.00.906w_1, 0.01.78.0906w_2 Multiupload.com - upload your files to multiple file hosting sites! MD5: CB2ABFCBF83F1680AFB7178558AFB6D0
If you need to refresh your memory on how to go about installing ROMS, read Cyber Warriors sticky. It shows you how to install the radio as well. You can do that after you install the ROM
Did you make sure you wiped data/cache before the install. Did you restore any kind of data? I've had no problems with video recording/playback
i did wipe the data/cache but I also restored it after everything was done.
You have to be careful on what kind of data you restore to a new ROM. Read Pete's sticky thread on backing up and restoring data. Then I would reinstall the ROM. Complete wipe, and deleting the extras folder beforehand.
Hi.
my backup pro does that as well :)
I tried to register over at bamf but that darn puzzle you have to do first doesn't work to the tbolt! It's funny you can't register on a phone forum with a phone!
thanks, I decided to reinstall the ROM and not restore the data and it works greats :)
It won't wipe your data. The only thing it does automatically is wipe the davlik cache. You'll still need to wipe cache if coming from .0.6
Cyber Warriors sticky has all the info you need for flashing ROMS. Read it :)
dftyuc
