[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
Do I have to wipe before installing 1.07? That note about wiping is not present on the 1.07 download link.
It depends on what version you have now. If it's 1.0.6 then all you have to do is wipe cache in recovery. If you're coming from anything else you'll need to wipe data
Reactions: The_Engine
Thanks. Can I just wipe the cache in ROM Manager? And this will wipe my data, right?
I wouldn't use ROM manager for that. You should only be using it to flash clockwork recovery. It's been known to be a little wonky, especially installing ROMS through it.
Wiping cache will not wipe data. Wiping data would ;)
LOL, I meant installing 1.07 will wipe my data, correct? And I have only ever used ROM Manager to install ROMs, so I suppose I have another learning curve. However, if I boot into recovery, I can find the option in there to install from zip, correct? 1.06 was the first I had flashed two days ago.
It won't wipe your data. The only thing it does automatically is wipe the davlik cache. You'll still need to wipe cache if coming from .0.6
Cyber Warriors sticky has all the info you need for flashing ROMS. Read it :)
Anyone lost 3g? I lost it today and had to restart the phone to get it back.
Working good for me... I'm usually solid 4G... until I left the coverage area earlier today and was in 3G coverage, which worked great also.... I'm running the latest 2.11.605.3 RUU radio.
Is there a huge difference between .6 and .7?
Sent from my Bamf'd HTC Thunderbolt using Tapatalk
Straight from the OP's POST:
1.0.7
Camera no longer crashes previewing videos
Edit > Effects now works in Gallery, this comes at the cost of a video icon in the drawer. Access videos via gallery.
Settings with radio options are present
Base updated to 2.11.605.3
BAMF Settings typo fixed.
Voicemail Notifications works, thanks erishasnobattery!
Mail has proper HTML support for Exchange users
****Note: If you get FCs after installation in Mail, use Titanium Backup to delete data for the mail app.****
Just flashed this and is running great. Does anyone recommend a good kernel to run with this? Mainly for overclocking and battery sipping.
Sorry, still new to this whole rooting experience. Do I need to reflash the radio that I'm running on .6 as well? I wouldn't assume so, but it never hurts to double check
Can I just flash 1.0.7 without wiping since I have 1.0.6?
Sent from my Thunderbolt using Tapatalk
I can't find the settings to undervolt. I am running this ROM with the latest radio and Imosen's 3.8. I have SetCPU. What am I missing here?
websitedesig88
