[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
I can't find the settings to undervolt. I am running this ROM with the latest radio and Imosen's 3.8. I have SetCPU. What am I missing here?
Never mind, I figured it out.
Sent from my ADR6400L using Tapatalk
I have always assumed data drops to be network and hardware related but no harm in asking....do you find data drops are more or less frequent with this rom?
I use widget locker so I don't care what version of lock screen I use.
Since I have never seen a data drop... how do you determine you had a data drop???
Hello,
I'm just a nub who has finally rooted my TB, THANKS to
[GUIDE] How To Root/Unroot The Thunderbolt with Revolutionary
I would like to install [GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
but, i have a few questions please.
Do i need to install any patches? if do which?
Do i need to install a radio? if so which?
What process should I follow while doing the above?
EDIT*
if you can just point me to the right radio, i think I can follow Cyber Warrior's guide
Hello,
No, just install 1.0.7... it's the full version... no patches required.
If you have the old stock Froyo radio... then yes... but if you have a new Gingerbread radio you will be just fine... go into Settings > About Phone > Software Information > look for Baseband version numbers... you can look at the "Latest Radio's" link in my signature to check the numbers.
Thanks for any step by step info, as this is my first time.:-[
The best procedure to follow is: http://forums.androidcentral.com/thunderbolt-rooting-roms-hacks/77350-guide-how-backup-restore-install-roms-thunderbolt.html... it has everything... how to create a backup... how to flash a new ROM... and how to flash a Radio... all within the first 4 or 5 posts... it's the best guide.
So I rooted the otherday, got rid of the bloatware and was enjoying playing with some of the Absolute app settings (fonts and what not), I did my backup and im flashing this now :) I figured, if I go halfway I should go for that home run
EDIT- awesome boot screen btw.
So i just wanted to say thanks to everyone who puts the time in here to help and or create these roms and what not.
Look people, I was uncomfortable about rooting and flashing but, after downloading the OTA GB and finding out how big of a disappointment is was I just had to dive in (I took the red pill).
I have to tell the rest of you who are afraid of rooting and trying a new rom to jump in! It was cake!
Just follow the new guide (How To Root/Unroot The Thunderbolt with Revolutionary) and try out this rom out. it is hella cool and my phone is way faster now.
thanks all, for everything!:)
Rooting for the first time is like taking off the blindfold. You just don't know what you are missing until you try it, and then the whole world opens up.
As anyone experienced the android mail app force closing?
Please read the opening post.
****Note: If you get FCs after installation in Mail, use Titanium Backup to delete data for the mail app.****
My backup pro also works.
Well I have done it, I rooted and installed BAMF Forever 1.0.7, now it comes back to setting up all my apps and everything again, heres hoping for the best....
You will love it as I do! This ROM is great , plus you get to say by by to blot ware! :)
Call me dumb but i forgot which version of Forever I installed. Is there a way to check the version exactly? Settings Software shows 605.0. Does that mean I'm on 1.06? It's either 1.06 or 1.07.
I recently upgraded from 1.0.6 to 1.0.7 and noticed when I click on the bottom left of my home screen to show all my apps, it comes up as it did on Froyo and not GB. The apps just scroll, they aren't so called 'sections'. Any idea on how to get that back or what I did wrong? Or is that just part of 1.0.7?
You're on 1.0.6
Try this: http://www.multiupload.com/IRVHT2RHJI
baabazambi
