[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
My next question, do I have to flash them in pairs, or can I just flash the cdma. Thanks for the help.
You can flash the CDMA from one radio and the LTE from another... that's why they are separated... it's up to you and ONLY you!!!
I just rooted and flashed this ROM today, I downloaded setcpu but I can't overclock my processor. What am I missing?
Sent via Tapatalk via Thunderbolt
Oh duh, ofcourse the kernal. Do I need to whipe data to flash this?
Just wipe the cache partition and the dalvik cache... don't wipe data. Flash the same way as a ROM in ClockworkMod Recovery. You don't need SetCPU with Imos kernels. They're already tweaked... SetCPU will just get in the way. You can control the CPU in the Bamf settings.
Will this work on 2.11.605.3?
Yes
How can I mod the battery icon to show the # % instead of just the green bar?
Go to teambamf.net and go to the mod forum... you will find a thread for battery icon modifications. Make sure they're compatible with the ROM. There's a thread for Bamf Forever battery icons. The 1.0.6 mods will work with 1.0.7.
Also... Bamf Forever already has the battery icon with the percentage inside of it. Do you not have this?
No I just looked at the screen shots and saw a solid green bar that's why I asked. I am downloading the cubed Rom now since I saw it say the version I'm running
Yea... that's at 100%. The icon will show the percentage from 0-99. You can also go the the Bamf thread I linked for extra battery mods.
@Adrynalyne - Does your Sense version have the HTC security flaw?
I believe that has not been patched on the current (1.0.7) version.
I also believe that you can "fix" it by simply freezing "htcloggers" using Titanium. Anyone here please correct me if I'm wrong.
Adr said in the bamf forums you could just delete it, and it will probably be gone from .8.
I tried freezing with my backup pro and it broke all my widgets, though I don't see why.
Quick question.
I would like to use the lean kernel but before I do I would like to know if BAMF Forever has ROM has a kernel included. I ask this because if I run into too many bugs with the lean kernel, I would like to know how to get back to where I am now, which is awesome.
Thanks,
Quick question.
Thanks,
Any of IMO's pages also include the stock kernel. I'm running lean 3.8.0 and it's fantastic.
Link http://rootzwiki.com/showthread.php...rnel-minimalistic-kernel-(3.8.0GBtest-9-21-11)
I used Root Explorer to move it to my SD Card, just in case... rebooted to be sure nothing was in memory... things seem to be working ok.
Reactions: djousma
I have been getting a force close of the htc mail app since upgrading to .7 Also my phone has frozen on 3 different occassions requiring a battery pull. Has anyone experienced any of these issues?
Please refer to the opening post. :)
****Note: If you get FCs after installation in Mail, use Titanium Backup to delete data for the mail app.****
Reactions: Slapnpop826
clive
