budlight-budlight
- Dec 29, 2010
- 106
- 1
- 0
1st time.. just rooted and gonna try this..still wanna understand the comments in the other threads about nightlies
so i flashed this rom.( first time ever ). i loaded the rom. recovered the apps and data from titanium, everything installe
d.. got it loaded up and now for some reason i dont see any available apps on the lockscreen. i went to where you can customize it, set it up but no apps show at all.. its just the plain 3.0 lockscreen with the bamf circle .. no weather in the background ( even though thats what i selected) and no apps. any help?
how come bamf settings says its denied root access and has to FC?
Question: do i have to flash bamf 1.0 and update to each version or can i just flash 1.07?
everything with superuser access wants to FC accept titanium root check says su binary not fouund or operating properly also get a warning com.noshufou.android.su stopped unexpectedly any ideas and what to do?
so i flashed this rom.( first time ever ). i loaded the rom. recovered the apps and data from titanium, everything installed.. got it loaded up and now for some reason i dont see any available apps on the lockscreen. i went to where you can customize it, set it up but no apps show at all.. its just the plain 3.0 lockscreen with the bamf circle .. no weather in the background ( even though thats what i selected) and no apps. any help?
Try rebooting to CWR and do 'fix permissions'.
that fixed the one problem root check to confirms root access but my backups and bamf settings still has a problem with com.noshufou.android.su supposedly stopped FC
has to be a problem with the root access 1st time at this so not sure what to do
Did you delete the BAMF_Extras folder from your SD Card before installing the ROM???
Try updating SU.
did that..still a problem i do only have the free version if thats makes a diff.
