[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
The biggest thing for me (which was one of the top reasons I bought the TB) is video chat (ACTUALLY USING A FF CAMERA!). I can't believe this still isn't possible yet. Did the new OTA have this? I know BF 1.0.6 had it, but the FF cam was sideways. Does 1.0.7 fix that (i'm updating now from 6->7)?
The FFC works fine with Skype and Tango and just plane old camera mode. People are saying it doesn't work with Google talk. I haven't confirmed that with me because I don't use Google Talk!
And which settings is it safe to restore from titanium?
I don't use Titanium app. I would ONLY restore app data. Personally I only restore 4 apps... Angry Birds, Angry Birds Rio, Password Safe, and Timeriffic... everything else I log into and setup... it might take me a little more time, but I've never had an issue with my apps or settings this way.
Reactions: recDNA
Maybe someone can help me. Before I rooted, I had both Facebook for Android, and Facebook for HTC Sense linked to most of my contacts. When I'd click on a contact in my people widget it gave me the option to visit their Facebook profile with either app (android or HTC Sense).
After root, I still have everything set up the same, and everyone is still linked, but it only gives me the option to view with Facebook for HTC Sense, which I hate. It also says "Account unlock" for some contacts. Can anyone explain this, and how I can get it to give me the option for the other fb as well?
* screen captures below
Click to view quoted image
Sent from my Bamf'd HTC Thunderbolt using Tapatalk
This may be a stupid question, but how did you change your font?
[*]You MUST delete the BAMF_Extras folder under your sd card prior to installation
How?
How?
Connect your device to your PC as a Drive, right click the folder and select Delete... or start some app like Root Explorer, go into sdcard, long press the BAMF_Extras folder, select Delete.
I'm confused...I should delete the folder before installing but installing creates the folder? If installing creates the folder there is no folder to delete before installing?
If there is no BAMF_Extras folder before flashing then you don't have to delete the folder. The reason for these instructions is that if you had an older version of BAMF flashed on your device earlier you would have a BAMF_Extras folder that by flashing THIS ROM it would not overwrite and would cause issues if it was still there prior to flashing this ROM.... therefore you would need to delete it prior to flashing this ROM.
Oh...so this is my first custom rom so no bamf extras to uninstall. I guess I'm ready to go. Don't need to rename as PG0IMG or anything?
i installed md5 checker and hashes match after downloading 1.0.7 to my computer so i guess i'm ready to go.
I didn't, but if you want official confirmation, I guess wait.
I tried using it with Tango ( I'm on forever 1.07) but the only other tango device is my son's iTouch. I see him well but he sees me upside down. Don't know how to fix that.
You don't need to rename the zip to flash the ROM...that's only required when you are flashing a new radio.
Reactions: recDNA
Anybody know if there's a fix for the "call end" bug? May be a deal breaker for me on this rom if not. Other than that it's phenomenal.
I don't know, I've never had the end call bug on 1.0.7. Did on 1.0.6 but that was resolved by flashing the 2.1 answer screen.
Try using only the default skin (the transparent one called Verizon). This fixed it for me.
Sent from my ADR6400L using Tapatalk
Reactions: Cyber Warrior
Try standing on your head when you talk to him. Justsaying...
cecilyharper
