GB .595 is out in the wild
It's official, I give up... SBFing back to .340, then making my way to .595 deodexed.
The stock .595 is being a little F'er...
How did you do it? I installed .588 with no problems. I am non rooted. Straight stock. However, I download .595, i put it on the root of my sd card powered down, went into recovery chose to install it from sd card (just like i did with .588). It will start extracting but it then says verifying update package........E-signature verification failed......installation aborted. Pleas help. I cannot seem to find a clear concise answer. I need step by step instructions as to what to do to get to .595.
Hi,
Does anyone have the Market fix.apk?. When I searched Quickclock Advanced, which is already installed on my phone it could not find the app. Thanks for the help.
oh....i downloaded the stock .595. I am not into rooting deoxed and all that other stuff. I only installed .588 becasue it was just drag and drop and then install (fool proof...lol). I downloaded .595 from my droid world.
On .588... You have to go to .591 first so go download the .591 file from somewhere
1. Go find GingerBreak 1.2 and root your device
2. Install DX Bootstrap (Clockwork Recovery) (be sure to disable USB Debugging when you want to use this so it will work...or you can use the D2 bootstrap and you can leave USB Debugging enabled)
3. Reboot into clockwork recovery
4. Go to "install from SD Card"
5. Select the .591 zip file
6. Tell it to install
7. Let it do it's thing
8. Reboot the device when it's done.
9. You'll now be on .591
Repeat these steps to go from .591 to .595
Reactions: scottabutler
Confirmed this works. I used these steps without even coming to this post yet.
I even installed directly from .573, no wipe/factory reset and no issues. Works great.
Okay thank you guys. I guess I will have to take the plunge. Hey will you guys be on stand by for me??? LOL....just kidding. Thanks for the quick replys.....here goes (holding my breathe as I jump into the water)!!! :p
Okay which .591 one do i need to download. I found it but there are three different versions.... fully odexed, fully deoxed or deoxed apps + odexed framework??? Which one is stock per say??
I have it somewhere in my Titanium folder but I dont know what its named. I think the apk I got was name changed. I'll keep looking.
Nevermind, check your PM SuperCharged
So, if im on the deodexed .595 will I get the ota? Or is it just the non rooted stock version?
Hey guys. I just want to say thank you for the help. I am now on .595. It was pretty easy. Now if I understand correctly...now that I am on .595 I will be able to get the OFFICIAL update when or if it is ever released?
Yup if your on the Odexed Unrooted .595 version,that wildman suggested to you .I think your good to receive the Official update.
Im thinking it may be june before it gets released tho
Dugoh1
