[GUIDE][8/1] Jelly Bean Now! Resources & Discussion
Re: [GUIDE][6/30] Jelly Bean Now! Resources & Discussion
DL Jake's Jelly Belly now ,ha :)
DONE! Did a first just now, <DEVIRGiNIZED> went into the zip file of Jelly Belly and saw that it looked A LOT like what you see when your nosing around in RootExplorer, replaced the BOOT.img (Franco) and my custom SPN-CONF file (Changed the carrier name) in their respectful places and VIOLA!
Is this technically my first custom rom?? :D
!!!SHWING!!!
Tapatalk Sent from the Future
Yeah I trashed his eri file, replaced with mine, and now I'm going to flash trinity.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
lol no, this is basic :-)
my gps worked well today then when i needed t on way home i was a 1/4 inch from the road was actually on besides that only apps im havng issues wth are vzw apps
I've gone from AOKP M5 to Vicious V2 to AOKP B40, and finally now back to tasty Jelly Bean, Vicious 3. Think I'll be sticking with JB because even though the customized nature of AOKP is what drew me ROMs in the first place, I'm actually enjoying stock ( or I guess technically stock-ish) even more right now. I was also curious about performance differences with GPS, etc. so while switching I tried Nav etc a few times. My GPS experience has actually been slightly better with JB than ICS. Locks quickly and regularly in areas I had previous issues and is more accurate. Weird, I know, since apparently the opposite has been more common but hey, I'll take being lucky
Beans in a Nexus
Edit: damn you auto correct
If I read that correctly... you were a quarter inch from the road you were supposed to be on? This GPS problem is really getting intense.. :D
(Quarter mile I assume, haha.)
My GPS locks up right away on my AXIOM ENGAGE JELLYBEAN :D
HUMONGOUS BIG UPDATE:
A general guide to softbricking/restoring your device and putting a custom recovery on your phone has been added to the tips/tricks post. Please double check this, I did it from memory, but i'm 99% sure it's 100% valid. :)
- D
do you have a link to that post please. I couldn't find it. Is it in the root/ROM/hacking threads or the general nexus tips/hints cause I didn't see it there. Thought maybe had some info that could help me with my problem.
Thanks
I am reasonably sure a guy on rootzwiki fixed the jellybean gps issue
I am running CDMA galaxy nexus ....flashed vicious jellybean v2.
razor2006, on 30 June 2012 - 04:51 PM, said:
Easy. Just create a file called gps.conf with the following information in it. Then replace the /system/etc/gps.conf with this one.
NTP_SERVER=server 0.us.pool.ntp.org
server 1.us.pool.ntp.org
server 2.us.pool.ntp.org
server 3.us.pool.ntp.org
XTRA_SERVER_1=0.north-america.pool.ntp.org
XTRA_SERVER_2=1.north-america.pool.ntp.org
XTRA_SERVER_3=2.north-america.pool.ntp.org
XTRA_SERVER_4=http://xtra3.gpsonextra.net/xtra.bin
XTRA_SERVER_5=http://xtra2.gpsonextra.net/xtra.bin
ACCURACY_THRES=80
SUPL_PORT=7276
SUPL_HOST=supl.google.com
OK ...so far so good! I think this is the fix WE ALL SEEM TO NEED! 300milez yesterday battling with GPS.........ugh.
This is what my GPS.conf WAS (as in the problem is below NOT the solution):
NTP_SERVER=north-america.pool.ntp.org
XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin
XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin
SUPL_PORT=7276
If that helps anyone diagnose.
To edit I used the root explorer in rom toolbox. Long pressed GPS.conf and hit edit. Renamed it GPS.conf back. ...is made another GPS.conf ....I edited it and pasted the solution there.
Reactions: JkdJedi
Thanks
Its halfway down post 3 in this thread , on the first page.
Reactions: dmmarck
Is this fake?? Sounds like according to this email I just got that Jelly Bean will be 4.2
ACCURACY_THRES=80
SUPL_PORT=7276
SUPL_PORT=7276
This is the one found in Jelly Belly (gps.conf)
NTP_SERVER=us.pool.ntp.org
XTRA_SERVER_1=http://0.us.pool.ntp.org
XTRA_SERVER_2=http://1.us.pool.ntp.org
XTRA_SERVER_3=http://2.us.pool.ntp.org
XTRA_SERVER_4=http://3.us.pool.ntp.org
DEBUG_LEVEL=0
INTERMEDIATE_POS=0
ACCURACY_THRES=0
REPORT_POSITION_USE_SUPL_REFLOC=1
ENABLE_WIPER=1
CURRENT_CARRIER=common
DEFAULT_AGPS_ENABLE=TRUE
DEFAULT_USER_PLANE=TRUE
DEFAULT_SSL_ENABLE=FALSE
SUPL_PORT=7276
SUPL_NO_SECURE_PORT=3425
SUPL_SECURE_PORT=7275
SUPL_TLS_HOST=FQDN
SUPL_TLS_CERT=/etc/SuplRootCert
C2K_HOST=c2k.pde.com
C2K_PORT=1234
Was about to change it but it looks similar to the fix above, will test this now, going out for a 2 hour ride, ;)
Anyone know if any of these newer ports fix the received MMS always in slideshow bug? I don't have any issues with my current setup, but was thinking of flashing jelly belly 1.6 if the MMS was working right.
Jellybeanin' on tapatalk
Slide show bug might be an inherited Android thing, especially if it's coming from an Iphone, anyway if theres a fix please let me know!! PM me por favor!
Is anyone's sports card working for Google Now? I cant click on My Teams.
LTE on/off switch no longer working on Jellybean, anyone have luck?
So, I'm super bored today, and I don't think I can hold my curiosity off any longer... What's the best, most stable JB ROM to go with, right now? Also, what, exactly, isn't quite working, in terms of the features? I've heard that, for example, the options in notifications (for instance, being able to "call back" right from a missed call notification in the drop down menu) don't work, but I've heard that's not true from other sources.
Glaywinpe
