How do I stop my voice text from repeating everything twice?
  • Start date Start date
A
AC Question
Every time I voice text, my phone repeats the sentence or paragraph twice. Anyway to avoid this annoyance?
My Nexus 5 is doing the same thing. It repeats numerous times. Happens when I use SwiftKey and Google voice..
here is an example here as an example hair as an example hair is an example hear as an example.
It gives every variation of what it thinks you said.
It happens with or without wifi, I don't have to speak more than 10 words. It happens with 4 words also. Only since update I am on samsung s5. Not just messenger. Any program that I use the microphone from the keyboard on it happens.
New here also guess we have to keep checking back new here also yes we have to keep checking back new here also I guess we have to keep checking back new hear also guess we have to keep checking back.. Lol
Same here man hope its fixed soon before this issues it use fo put Chinese characters now this duplicating issue duplicating is shoe duplicating is she duplicating issues duplicating is XU
My Wi-Fi is off why WI-Fi is off my Wi-Fi is off just always use mobile data in county
None of these "fixes" work. It is a server problem with google. I confirmed this earlier because my S7E is upgraded to Nougat on VZ with Google Now set up, and my fiancee' s HTC M10 on VZ is on marshmallow with no Google Now capability. Both phones have the issue.
My issue cropped up with no Wi-Fi on, and I tried disabling the "ok google" feature. VZ doesn't support enhanced LTE to my knowledge so that's moot.
Also you need to speak a sentence with at least 10 words to trigger it, so if your using less than 10 words it will appear to be fixed.
testing one two three will still get a problem since it also wants to try 1,2,3
I have an XL and am experiencing the same issue
I just updated several apps a couple days ago
I uninstalled the latest update on several of those apps
That did not fix it
That did not fix it
That did not fix it
Lastly I retrained my voice through the google app and so far so good. ;-)
I am going to update the apps I rolled back and see what happens.
Йосиф
Im having the same issue. Ive uninstalled the google app update. Reinstalled it, uninstalled again. Power cycled phone. Nothing is working.
Im on a samsung S7 edge running Nougat 7.0
Help please!
So, I have the S7 edge. This evening speech to text just started replicating everything by at least 3X's.
Happy to report that a few minutes after disconnecting from wifi that the issue stopped! Thanks Kevin!
no more repeated text. I have no idea if it's a coincidence or not but I started having this problem shortly after activating the Visual Voicemail app.
I have a Galaxy S5. It gives me all the options that autocorrect would offer. Not exactly repeats. For instance:
I hope I can figure out how to uninstall the update.I hope I can figure out how to uninstall this update. I hope I can figure out how to uninstall the update period
Anyhoo... I subscribed to the thread, so hopefully when a fix gets mentioned, I'll be alerted. I hope that's how this works.
I have a Galaxy S6 and it just started doing this today also I have the Galaxy S6 and it just started doing this today also I have a Galaxy S 6 and it just started doing this today also I have a Galaxy S six and it just started doing this today also I have a Galaxy S6 and I just started doing this today also
When you are out and about it will not happen it only occurs when Wi-Fi is enabled
Not true. I turned off wifi and it still did it
Arwen
