[How-to] Guide to Rooting with software version LS670ZVC
Status
Not open for further replies.
I would then try running the checksum on the cab file to see if it is the same.
Unzip the fsum utility and place fsum.exe in the KP500-Utils-EN-v0.4.2 folder
Then run fsum from a command prompt.
start menu->run
cmd.exe
c:
cd \KP500-Utils-EN-v0.4.2
fsum *.cab
as far as i can tell its good I am at a loss of what to do right now i have no clue
C:\>cd \KP500-Utils-EN-v0.4.2
C:\KP500-Utils-EN-v0.4.2>fsum *.cab
SlavaSoft Optimizing Checksum Utility - fsum 2.52.00337
Implemented using SlavaSoft QuickHash Library <www.slavasoft.com>
Copyright (C) SlavaSoft Inc. 1999-2007. All rights reserved.
; SlavaSoft Optimizing Checksum Utility - fsum 2.52.00337 <www.slavasoft.com>
; Generated on 02/13/11 at 23:56:16
54d830c33567fccbb550f879a2ede136 *LS670ZV9.cab.cab
Ok, your cab file is correct. Trying to figure out why it isn't working for you.
Try this, for KP500 enter
Model #: LS670
Cab File: LS670ZV9.cab
Version: LS670ZV9_20
If that doesn't work try
Model #: LS670
Version: LS670ZV9
Hmm, I just noticed your cab file is named
LS670ZV9.cab.cab
It should be named
LS670ZV9.cab
Try renaming it, and rerun fsum to make sure it took the change. Sometimes windows hides file extensions, making it confusing what is the actual name being used.
hmmm ok it was working i had service again but the lg program gave me the same error again and i am without service again
ok i was curious about that myself i will change that real quick, but on my file when i renamed it earlier there is only one .cab not sure why it has two on the fsum
I think it is because windows is hiding filename extensions, so even though you see one .cab extension, there is another one hidden.
In your command prompt type
c:
dir *.cab
If the file is named LS670ZV9.cab.cab
then type in the command prompt
ren LS670ZV9.cab.cab LS670ZV9.cab
dir *.cab
Is there still a folder named KP500-Utils-EN-v0.4.2 in your drive C?
I think you are actually making progress. The file naming problem could easily explain the file extraction error. After you get past that, the utility should be ready to start flashing.
Were you able to rename the cab file to get rid of the double .cab.cab extension? That I think is the piece that would allow you to progress.
ok i got it running i did a test it was cab cab so i typed in what you told me to and the end result is at the bottom with a single cab lemme know what you think
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\kim robbins>cd C:\
; Generated on 02/14/11 at 00:55:33
C:\KP500-Utils-EN-v0.4.2>dir *.cab
Volume in drive C is ACER
Volume Serial Number is 9640-13DC
Directory of C:\KP500-Utils-EN-v0.4.2
02/13/2011 08:41 PM 99,220,700 LS670ZV9.cab.cab
1 File(s) 99,220,700 bytes
0 Dir(s) 128,576,172,032 bytes free
C:\KP500-Utils-EN-v0.4.2>ren LS670ZV9.cab.cab LS670ZV9.cab
Excellent, you can now try the KP500 utility again.
Model: LS670
cab File: LS670ZV9.cab
ok so it went through the whole process and loaded phone is working now to move on the the next stage you are a life saver thought i would be without my phone for work tomorrow thanks now is there anything i should watch for as far as updates that want to install?
What are you trying to accomplish?
If you are happy with V9, then you can stop here, but you'll get nagged for updates (don't accept OTA updates)
If you want VC but still want to root, then you'll need to do a little more work and restore the V9 Recovery partition. Once you've done that, you can use the LG Software Updater tool to upgrade to VC. After that you'll have a VC system with V9 Recovery partition. You won't get bugged about updates and you can root at a future date if you still desire.
Reactions: scooled101
Status
redmercer
