[How To] Root Galaxy S4
Hi, I'm new to the board.. I just spent a bunch of time trying to root my Galaxy s4. It is SGH-I337M. I don't know what I'm doing wrong, I've tried a couple of methods. Could someone point me in the correct direction. I consider myself to be computer savvy and now this is just making me crazy!
Thanks in advance.
Update: Nevermind, I figured it out. :)
Hello All,
I have a S4 with Canadian network provider Rogers wireless. Was wondering if someone could please tell me if my bootloader was locked or unlocked? How do you tell? If locked, how can i unlock my bootloader?
I've followed the instructions, but when I open the superuser, It says that I must update the binary(su). But when I chose to install or recovery install, both of them failed. And it said there was an error installing superuser. And my s4 doesn't rooted. Any help ???
Hello All,
I believe its unlocked
Ive completed all the steps, i open super user and it says it needs updated, so i hit install then it says "There was an error installing Superuser. PLease send a log of the error to the developer"..HELP
Hello,
I would really appreciate a little help:
today I tried to root my samsung galaxy s4 GT-19505 according to your guide and recieved the following error:
rm failed for /data/local/tmp/pwn, No such file or directory.
the same error appeared for the su and busybox files,
although they are present at the same directory as the run.bat.
the application is saved on my samsung device in documents folder.
should it be at some other location, or perhaps on the PC itself?
Thanks a lot
Anna
You have to take the KNOX plunge and flash stuck via ODIN 3.7. Good luck, searching xda will help.
hello i did all of above in the guide, using OSX, but in the terminal it only says file or path invalid after i started the run.sh
what have i done wrong?
If your running mk2 (4.3) to my knowledge there's no mac root method and if you updated to 4.4.2 there isn't a single root method at all for kit kat windows or mac
must have unlocked boot loaders!!
Hope to get root for KitKat (4.4.2) soon (Galaxy S4 AT&T SGH-I337).
Any news will be very appreciated.
There is no root method for kit kat at this time and from what I'm reading due to knox and the current libraries in 4.4.2 rooting may not be even possible they locked down the boot loader as well as the o's keep checking on xda but people have basically bricked their phones trying
Cheezy313Bby
