Infinite bootloop- help!
CellTheUltimateAndroid
279
Just received the n6 today and there was a notification to update to 5.1. I downloaded and updated it and now it is in an infinite bootloop- keeps on saying optimising 125 apps. (BTW this was completely stock- I didn't even sign in to my Google account) . I tried recovery mode wipes and endless reboots but nothings working- help please?
Re: Nexus 6 bootloop
I can't imagine that it would have any effect on your warranty, so long as you download and install the correct official OS file.
Sorry, but I do understand.
Using the Nexus Root Toolkit, you should be able to easily repair your device, whatever the problem may be. It will reinstall the stock OS. Your only other option is probably to contact whoever you purchased the device from (Google?) and request a replacement.
I'm sorry if I sound noobish but can you give me a step by step guide on how I can fix the nexus? Thanks
I'm not being funny, but if this is a new defective unit I'd be straight on the phone for a replacement. Who knows what else may be wrong with it.
After all, you're paying for something that doesn't work at the end of the day.
I know what you mean but Itll take a very long time for a replacement (as its Motorola) and I really want to keep the phone )
Guys these are my options
1) sideload an ota through root toolkit
2)
Wipe data and reset using nexu
S root toolkit
Thing is, my bootloader is locked and USB debugging is disabled.
Re: Nexus 6 endless bootloop
2)
S root toolkit
I found this to be the most useful. Remember, fastboot and usb debugging are different. You don't have to have anything enabled to boot into fastboot.
www dot androidforums.com/threads/guide-how-to-flash-a-nexus-factory-image-manually.706533/
Seems I solved the problem myself. I used the rootkit- I basically just unlocked the bootloader and then reset it and flashed marshamallow 6.0.1 and I'm gonna relock the bootloader tomorrow. It was easy enough even for a noob like me.
Good job!
Pretty soon you'll be able to call yourself a pro. :)
Omar Boresli
