JT Super Clean Rom available on Rom Manager
The system dump has it. It does not have to be deodexed. There is no odex file with it. It is called thinkdroid.
now why didn't I check my CWM backup? I just assumed it had a corresponding Odex file stock. You know what they say about assuming :D. Thx.
There are a few apks that I had to add. there was a bluetooth app that had to be added back for my v1 voice commands to work. All share is another app I added.
Anyone else notice a change while running the jt super clean and the non voodoo kernal with the android keyboard. Before the letters to pop up and show in the box and u pressed and now the box is just ... anyone else encounter this
Sent from my SCH-I500 using Tapatalk
I installed both of these and I still get the predictive text. You might want to go into your keyboard settings and check your options.
yeah I'm seeing the same thing. The words pop up every once in a while but not every time.
You can leave it alone, if you want to run the completely stock kernel. But i would use the "stable Non-Voodoo Kernel 11/06" personally if you don't wanna dive into using a Voodoo kernel. Because you'll notice it's alot faster and even get's better battery life than the completely stock one. Just make sure to do a nandroid backup before trying any kernel, just you have it. :) Hope this helps.
Thanks for the tip! I'll try reflashing to update to non-voodoo.
Yeah, I just spent the last hour adding all of my AppBrain apps. I think I'm going to rerun the ROM and install the non-Voodoo kernel
remember, it's not a backup, it just makes it easier for you to remember what apps you have installed and it'll give you the install links afterwards. after I wiped my phone, I had to spend a good 20 minutes or so installing apps back on. not as long as having to hunt down every app through the market tho. good luck with everything!
That did it for me. It looks like it resets the Swype settings so you have to re-enable the predictive text.
I wasn't talking about the predictive text I was talking more specifically about the individual letters that would pop up when u hit a character while using the android keyboard
I'm having a problem with ROM manager. When I try to download a ROM or anytime it needs to connect with the server it says:
"Error occurred while downloading the Developer list." or other similar server errors.
My SDcard has PLENTY of space and my connection is great. Think this is on their end? I've uninstalled, reinstalled, etc..
It worked a week ago, and now I want the super clean ROM and can't download it. :( :(
Fixed: Deleted all items in my downloads folder, seemed to fix the problem.
Yeah I see that also...needs to be fixed.
if you flash a different theme it should fix itself, some themes are messed up in the popup theming.
From the rom manager dl, the theme has the problem w/ pop up letters not showing... 2nd and 3rd theme in jt's section.
Any news on the DJ05 update? I'm hoping that we'll be able to port this over sometime this/next week... Odin is easy enough to manage, but I really do not want to have to go back to stock and lose Root/CWM/etc. in order to apply the fixes.
I'm also finding that traditional typing with the swype keyboard is a lot less accurate with this rom than it was stock.
I have themed my swype keyboard so when I pres a letter it is highlighted but I only ses the popup boxes if I long-press.
Hey, just wanted to say thanks to everyone who posts to help out us android newbies. I did a lot of research when I knew I was going to switch from ATT to Verizon, and had completely decided on a droid X due to the fact that it had Froyo and great audio/bluetooth/gps hardware. However, after reading these forums, I decided to go with the Fascinate due to how open it is. It's been really easy to root and flash a new ROM to my phone, and, despite missing the great GPS functionality (hopefully fixed soon) and ability to use my wiimote to control the awesome emulators, I'm really pleased. I love to open up my gadgets with custom firmware/ROMs/kernels etc, and the Fascinate seems like it's going to have a nice community around it.
I'm curious though-- I flashed JT's ROM mostly to get google search as the default. In regards to the de-bloating, I haven't noticed many speed improvements, but my phone was flying before I installed the ROM. (I had debloated with the freeze function on Titanium Backup Pro before, however) Touchwiz actually isn't so bad-- it feels much smoother than blur, and is definitely smoother than my iphone 3g.
I guess my question is, did anyone actually have a 'slow' fascinate once they performed some rudimentary de-bloating, and maybe installed a new launcher? This thing is so fast, I have trouble believing people can see it as slow.
Debloated myself and phone was slow. Put bloat back and installed JT's Super Clean Rom and phone was snappier till I started downloading apps.
Found out LauncherPro made things less laggy to I used that for awhile.
Discovered kernels and my first flash was StupidFast kernel by geeknik. That elimininated 99% of my lag.
Everyone has different experiences with this stuff so what you find hard to believe it actuality on someone elses device.
My iphone 3gs was twice as fast as this but I have come a long way and love my fascinate now.
Can you tell me more about how to get the wiimote and emulators working? I haven't gotten into that yet but sounds like something my son would love.
@ zgrunau I would definitely suggest trying the StupidFast kernel. It should eliminate most lag if not all lag. It really is "stupidfast" lol.
AFAIK the wiimote cannot be used with our phones, or at least not yet. Depending on what type of emulator you want, I recommend nesoid, snesoid, gameboid, and psx4droid. Also download ROM Gripper for easy downloading of roms for nes, snes, and gba. For PSX roms I would suggest Rom Buddy PSX. I hope this helps and just so you know, some of the roms can be a bit buggy especially the PSX roms.
Just want to thank everyone for posting this and making it easy and accessible for everyone. I went, in two short months, from not knowing anything about android to having a rooted, debloated, faster phone that is literally the envy of my friends. I liked my Fascinate before, but I am truly starting to love it. You guys, and Android Central, rule.
I do have one question. It looks like any time I want to change ROM's or install a different Kernel, I have to completely set up my phone from new again. Is there any way to avoid having to do that, or is that just part and parcel of the whole process every time?
periyasamy
