ARCHIVED: [Kernel][CM7] XioniaRedux 2.6.32.33-ck2 08312011
Status
Not open for further replies.
Game is called robo defense. In level 50-ish is when it would have an issue (more enemies on the screen). And that is a typo from using my phone. Lol. Week=seem.
I will note that turning off the "better" graphics option seemed to solve it while running this kernel. Just want to help point out any issues with the kernel in hopes of improving it. ;) thanks again for looking into it!
And just to confirm, you ARE running data2ext, right?
Re: [Kernel][CM7] XioniaRedux 2.6.32.33 07252011
I have been running data2ext the whole time I've been on cm7. Not sure why this popped up after flashing the kernel. Flashing your newest build now to give it a try. Will turn all the graphics up and give it the full test again. ;)
EDIT: Attached screenshot for eye candy. :) battery life much improves while running this kernel! Upside down for some reason...
I'm liking this kernal. I switch between picasticks and this :3
Sent from my clean optimus using a gameboy advance :3
22 hours at 10%? Holy wow! Gotta admit I was NOT expecting that.
Here's my recent screenshot for ya.
I'm definitely enjoying the battery life improvements I'm seeing. ^_^
Is this with or without Collin battery tweak thingy (screenshots)? Been loving the kernel so far.
I just flashed your kernel and overclocked it at 768 i went in to Quadrant standard and some how my score is 2425 with a stock SD-card which is crazy to me because i usually get around 1100 overclocked at 825 with Xionia kernel. Keep up the good work.
Quadrant has all kinda if glitches in its database. Try running the program a few times to get a consistent idea of your score.
sent from my Cyanogen Optimus
Did I miss the part about why my screenshots are upside down?
I think it's the most recent build of CM7 from ath3nos. Other people on that thread had that problem after updating. I stayed on the 7/9 build. If it's really bothering you though, you can rotate pictures in gallery.
I think you're right. It's fixed upstream though, my screenshots come out just fine.
this kernel does appear to lag on weird circumstances. basketthis and I are running data2ext.v4.
I assume it has something to do with writing to the sdcard. this was not noticable with the previous kernel on athenos
Sent from my LG-LS670 using Tapatalk
well I switched t smartass governor which for me it was not the default cpu controller. things have dramatically improved.
I also bumped my vm heap size to 48mb. I'm trying to find the right cpu configuration to overclock with on this phone. So thank you the difference was on my end.
I'm going to try to mess around with that battery tweak next. but so far so good with overall battery life with this last update.
*btw this swype 3 beta kicks a$$*
damn dude...not only did you fix it in less than 24 hrs, accord to your naming convension youd have had to rename it :-) id have never thought that the batt life could be that much improved.
and not only do we get it fixed but an educational explaination to boot! gotta love the world of open source....thanks for all yer hard work.
Re: [Kernel][CM7] XioniaRedux 2.6.32.33 07272011
[INFO]XioniaRedux 2.6.32.33 07272011 Release:
New in this version:
1) TinyRCU update
2) Mass storage csw hack, mass storage ops should be faster (YMMV)
3) Internal build mechanism changes
If you are running kernel build 07252011 or earlier, please update at your earliest convenience.[/INFO]
Status
godef
