LG G4 front facing camera not working, even after factory reset and new camera. How can I fix it?
  • Start date Start date
A
AC Question
I got an LG G4 H812 and it was working fine until a few days ago when suddenly using the regular app for front facing shots would fail sporadically, saying "Unfortunately, camera has stopped working." It would work after a few tries and then again stop working. Then, the front facing camera stopped working completely [rear is fine, no issues].
I did a factory reset, cleared cache and no change. Sent it for repair at a local shop [since I misplaced the receipt] and got a new camera in but it still doesn't work!
Any ideas or suggestions? The guy at the shop suggested flashing the original software onto the phone since its not a hardware problem. Isn't that the same as a factory reset?
Re: LG G4 front facing camera not working, even after factory reset and new camera
No. Reflashing software is not something to be undertaken unless you know what you're doing. You'll need a PC or laptop. There are members here who could guide you if you wish to proceed.
Kyle TW
