2. leave GPS running on you phone and make a nandroid. after nandroid is done. restore one of you older nandroids that you know for a fact has working nav, when you restore it, turn on NAV and GPS. then go into ROMmanager and restore the nandroid you just made of this. that also, should allow you to use your nav and gps...
I did this and the GPS now works like a champ! Thanks guys! Those of you having issues with GPS should follow the steps above. It takes about a half hour and well worth it. Hope this helps other people out.
Sent from my ThunderBolt using Tapatalk
