Llama - Who's Using It and Any Good Examples?
Having trouble setting this even up. If I am not at home or at work I want LLAMA to see if it can connect to the BT in my car.
Thoughts?
Thoughts?
I'm really new to llama, but I've been playing with it, and it seems like that might be better accomplished with an NFC tag in your car. I bought a couple and they were easy to set up with llama.
Sent from my Nexus 4 on Solavei
Thoughts?
One option could be that when leaving home or work and not connected to your car, turn Bluetooth on for a few minutes, and repeat every few minutes. The problem with this is that it will keep running until you connect to your car. But you could correct that using variables, stopping the event after few minutes (half of an hour maybe)
Another option is to enable Bluetooth polling. So when you are at home or work you set it to never, and when leaving either place you can set it to every five minutes for example, this is equivalent to the previous option and had the same issue, not fixable.
Hope this help you.
Enviado desde mi GT-N7000 usando Tapatalk 2
Hi, I need help setting up a profile.
I am using those events:
At home(cell area) - enable wifi and disable mobile data
Upon living home - disable wifi and enable mobile data
When I am near home, how can I disable wifi and enable data. This event is not working:
At home when your phone disconnects from dlink delay 30 seconds (if false not running) and then disable wifi and enable mobile data
Thanks
I am looking to get an event that does the following:
syncs my accounts every 10 minutes, then disables autosync. repeat ad infinitum. Very simple....but how!!
OR even better, I am not fussed about most apps that require sync but DO want my Gmail to get to me as fast as possible, how could I get round that?
There are many examples on here that are very complex and difficult to follow!!
Finally, is it possible to export events so others can simply import them rather than follow long complicated steps to duplicate events?
my events:
Name: Leave office text
On MTWTF
upon leaving WORK
between 17:20 and 17:55
run locale plugin and Send SMS to the wife "On my way"
Name:No Wifi data on
When not at Home nor Work
Enable mobile data, disable wifi, change profile to Normal
Name:Quiet at Night
At HOME
between 23:00 and 6.30am
disable mobile data
disable wifi
change profile to silent
When in my 4 identified wifi areas
disable mobile data
enable wifi
change profile to normal
Thanks
Hi, I don't see why it doesn't work. what exactly happens?
my events:
On MTWTF
upon leaving WORK
Name:Quiet at Night
At HOME
disable mobile data
disable wifi
disable mobile data
enable wifi
Hi,
First, you can share events trough the share option in the contextual menu (long click on an event)
Secondly, if you keep wifi on all the time at home then the simpler event for syncro could be like this:
At home, active syncro and force update, repeat every 10 min and Queue the following event:
After the amount of minutes that you want syncro (every ten minutes of syncro 1 or two minutes should be enough)
disable syncro.
Best regards,
Hi guys,
I'm using Llama for quite some time but I think I'm having issues with the update as in the 1st post (see below) and tweaked a bit (in RED, what I've changed) but it seems the phone isn't updating as it should.
Am I doing something wrong? Is there any other way (easiest way) to configure llama to update every 1 hour?
Your help would be greatly appreciated!
Thanks!
"Event Name: Screen Off
Advanced:
1. Delay Event
2. Delay Minutes : 1 minutes
3. Cancel Delay if False
4. Repeating Event
5. Repeat Every 10 Minutes
Conditions:
1. Screen Off
Action:
1. Queue Another Event (enter these details for the Queue Event):
-->Event Name: Data On
--> Queue Delay: 9 Minutes
--> Actions: Toggle Mobile Data On
2. Toggle Mobile Data Off
I updated these settings as follow:
Advanced:
1. Delay Event
4. Repeating Event
5. Repeat Every 1 hour
Conditions:
1. Screen Off
Action:
1. Toggle WiFi Off
2. Queue Another Event (enter these details for the Queue Event):
--> Queue Delay: 55 Minutes
3. Toggle Mobile Data Off
Hi,
disable syncro.
Best regards,
I do have wifi on at home all the time, but i want my sync to be activated every 10 mins ( lets say) all day regardless of wifi/data conditions so that i get my emails all day long, except for when my "Quiet at night" event is triggered, when i want everything off (but i still allow calls to come in just in case of emergency)
My attempt at an autosync event:
Advanced: repeat every 10 mins
Condition: time between 6:30 and 23:00
action: toggle account sync, request update
action: queue another event called Disable Syncr
Queue delay : 2 mins
conditions: none
actions: disable sync
When i try and test the above i get an error (Llama error: failed to queue another event. There is already an event called Disable Syncr
Why???
EDIT: Despite the error it seems to work. Now i need to perfect the event for different days of the week, when charging etc.
Hi guys,
Thanks!
Advanced:
1. Delay Event
4. Repeating Event
Conditions:
1. Screen Off
Action:
Advanced:
1. Delay Event
4. Repeating Event
Conditions:
1. Screen Off
Action:
1. Toggle WiFi Off
Hi,
You turn data and wifi on/off but you do not request any update...
Right! :-X
So I should just create an action after the "Toggle Mobile Data On" with "Toggle account sync", right?
My general idea with this is that when the screen is off, to have an account sync (Gmail, Facebook, etc.) every hour only and then disable mobile data again so my phone won't be constantly connected.
Maybe there is an easier way to do so?
Thanks for your help!
Right! :-X
Yes.
I think that yours, along with the one I suggest a few post above are the simpler ones. Also, that way of syncro had its issues that I pointed out a few more posts ago.
BR
You can use Ds battery saver. When you install this application there will appear in Llama in condition locale plugin for Ds battery saver. Or you can let running application Ds battery saver. :)
I did not understand.
I'm very sorry my English is very poor. This application is for synchronization and when is screen off then data and wifi is off. You can also every 5,10..... minute's synchronize when is screen off.
When you install application you can maybe use this event:
Conditions
Time between 9-17:00
Action
Locale plugin - Ds battery saver
Best regards
agreed a locale plugin in pointless,
my simple code works brilliantly. Every 10 minutes my autosync turns on for 2 minutes then turns off
conditions: none
But for those who are synchronize for example Dropbox when is screen off data will be off. And Ds battery saver has whitelist for this situation. Every man has different wants and this is easy way for this. :)
Hi
The general idea I have, as I said before, is to have an account sync performed every 30 min, either on wifi (when I'm connected to a wifi network) or mobile data (if not connected to any wifi network) and to turn off mobile data when I'm not using my phone (as I don't have a very big data plan).
So, do you think I can have these 3 events at the same time:
- SYNC: (to run the sync every 30 mins)
-> repeating event (every 30 min)
Conditions
-> between 6 am and 1 am
Actions
-> enable account sync, request update
-> queue event after 5 min, disable account sync
SCREEN OFF (to disable wifi + mobile data when screen turns off... will the sync still occur?)
Conditions
-> when screen turns off
Actions
-> disable wifi (if not connected)
-> disable mobile data
SCREEN ON (to enable mobile data when user is present, wifi should turn on if I am in my wifi areas I guess)
Conditions
-> when user is present
Actions
-> enable mobile data
What do you guys think?
brasio
makes sense to me! Not sure why for your sync event you need 5 minutes though, surely 1 or 2 is enough to get your mail/facebook etc.
baby boy
