Note 20 Ultra N986U carrier universal and unlocked models firmware
Has anybody with a universal unlocked note 20 ultra had problems with the phone getting hot while charging it.
Thanks.
Since ATT out with Android 11 any chance there will be an Update file the rest (T-mobile, etc) of us can use with the SD method?
I upgraded to android 11. On December 27th.
My power button got turned into the Bixby button.
All my Bixby settings got turned on..
All my emergency alerts got turned on..
It disconnected my phone from my car.
Went to a corporate Verizon store today....
They couldn't help me.
Went to a Best Buy and got to see a Geek.
He went into Bixby side button settings and turned a option off that is you press the side button it does nothing.
Then turned all Bixby settings off.
I've came on Android Central forums to talk about it.
I got pushed in a locked forums settings so nobody could reply to it.
I would not upgrade to android 11 period.
Unless you want a headache.
Which thread? Where you talked about ok Google twice not bixby ? Yeah multiple topics are not allowed in the forums .
https://forums.androidcentral.com/showthread.php?t=1017709
https://forums.androidcentral.com/showthread.php?t=1017629
The part is you go into Settings. Go to Advanced features.
Under advanced features you choose Side Key.
Under side key you will see , if you press the side key for it to do nothing
If you press the other option of side key it wakes up Bixby.
I didn't want the side key which is the power button to do anything if I pressed it but cut the phone off.
With the update of Android 11 . You need to press the down volume key and the power button to cut the phone off.
Why Android 11 changed this I do not know.
Look at Mike's screen shot
I like it.
I wasn't showed that way on mine.
Why is Android making the changes.
And turning all the alerts on.
And turning on most all notifications ?
It also moved my side panel on the screen from the left hand side to the right hand side.
I like it.
Hold that bar and drag to other side and lock it Screenshot_20210103-203334_Edge%20panels.jpeg
Hold the side panel where.
It don't drag.
But on its own.
It can move it from the left hand side to the right.
Is this android 11 not a Google update ?
With me having a Note 20 Ultra 5G universal unlocked phone.
It should be a Google update.
At the Verizon stores, they have on their computer.
Wait for a new update to fix everything.
What is going on ?
Why did they release it , changing everything on people's phones.
You have to go into edge panel settings and you can move the side. It happened when I upgraded my S10+ onto android 11 beta. Screenshot_20210104-115135_Edge%20panels.jpegScreenshot_20210104-115142_Edge%20panels.jpegScreenshot_20210104-115147_Edge%20panels.jpeg
Thank You catwoman.
I handed my phone to the OL.
She went in there and did that.
And again.
Why is all this happening ?
I'm on a new Chemo right now.
And my head ain't working well enough to keep up with all of this.
Thank You catwoman.
And again.
Sorry about the chemo. Get well soon.
pramanj96
