- Feb 6, 2017
- 97,744
- 13,807
- 113
T-mobile not out yet , that's the latestI did that and it only shows the older software I already have on the phone
April 1 update ending in DUC8
You have unlocked version or sim unlocked?If it's unlocked, do I have to have tmobile?
Go to settings>about phone>under phone number your model number ?Not sure! I purchased unlocked US directly from Samsung. Put my tmobile Sim in. Should be able to work on other carriers.
Not unlocked carrier phone.
Thanks SO much for the help!
Ok good , you have unlocked version like me , use XAA as region and flashSM-N986U1
No problem, once you download to computer then use 7zip to extract the firmware, open odin and each corresponding slot in odin match the firmware except last spot in odin leave alone and CSC use home firmware in odin slot so it doesn't factory resetGreat!
So I search for the firmware using Frija and save all 5 gigs to the computer? Then open Odin and somehow import the files into the correct spots?
Sorry, sounds easy but don't know the steps![]()
Yeah , Your Welcome !Great! I'll need to download 7zip. Just Google it?
Will try tomorrow!
Appreciate all the help!
No not at all , need more help just askThanks for the help and info. Hope you don't mind continuing to walk me through this!
Csc slot in odin put home CSCAlso, where is home firmware for the CSC slot?
Leave blank?
Ap firmware goes into Ap slot in odinOkay, help please. I can insert everything into Odin except AP. Md5 error. Binary invalid
Advice?
It shouldn't matter but try thatAP won't load into AP spot. Error message.
Maybe I should connect phone first?
