[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
I have to run but no you can not use the clockwork i provided for 2 reason
1. because i do not support voodoo as i dont want to be par of any physical damage you possibly do to your phone
2. i use a clockwork that has broken voodoo section ,,if i use the voodoo recovery on first boot it goes into recovery directly at power up and it does not wipe the phone and install the odin flash and the phone bugs out.
for a recovery that works use this thread
http://forum.androidcentral.com/ver...clockworkmod-recovery-updated-02-20-11-a.html
dont worry about the first part about it now working, just flash the tar file he provides. ok i got to run ttyl
when In Ti backup, I did restore missing apps with data. Should I have done restore all apps with data? or restore missing apps + all system data?
everytime i flash something(about 20 times in last month), i end up having to manually restore my homescreens, sound settings, keyboard settings, stuff like that. i use titanium backup to restore all my apps with data, and backup assistant for my contacts. its all a pain in the ass, but im still learning too. sorry i cant be more help.
Reactions: putney1477
Quick question about the Update.zip file. Do you unzip to SD card or just place the whole file there? Getting ready to update and wanted to make sure I didn't screw this part up.
thaks for all your help...i dont think i need voodoo anyway eb01 is running great on my phone
Hi - in installed DroidXCon's "Debloated/Deodexed Froyo Leak+root+Froyo Clockworkmod" a few weeks ago and my phone baseband is now, S:i500.04V.EB01, Kernel version 2.6.32.9 - I want to get SuperClean 2.5 on my phone...I have odin...how can i go about doing this? - do i have to data wipe etc?
this is what i did
wiped data, cache, dalvik
flashed DL09 with odin
flashed EB16SC2.5 with odin
hope that helps
Reactions: jabibister
There are 3 things that are generally wiped. The main screen of cwm has options to wipe data/factory reset and an option to wipe cache. The first will wipe everything and not required unless you run into problems. The wipe dalvik cache option is under Advanced in the cwm menu. It's usually a good idea to wipe cache and wipe dalvik cache going between roms.
I see the first two options, but I don't see an advanced menu - this is what i do - i open up rom manager and then choose to "reboot in recovery" - then my only options are to "reboot phone", "apply update.zip", "wipe data/factory reset" and "wipe cache"
sounds like you're in stock recovery. Hit apply update.zip.
I hit "apply update.zip", and it does it's thing and brings me back to the original screen described in my previous post...according to ROM Manager, I have CWM recovery 2.5.0.4
tech gropse
