Optimus S gROM 2.3.3 HELP
BZOptimusS
Active member
Jun 6, 2011
43
I have this sweet new ROM I downloaded last night, and I'm stuck between going the route of installing GingerKernel, and using SETCPU, or using the colin_ph Battery Tweak..... any pros out there with some advice? I want a fast Optimus, But not a buggy one that reboots and hangs. Any advice would be wicked. Thanks all :)
Specs:
Custom Battery @ 5100 mAh 3.7 VDC L-Ion (will post a thread later on this, mind = blown)
Xionia 1.2518.6 Custom Recovery Console
gROM 2.3.3 with GingerKernel flashed for OC'ing
.........currently hanging up @ 40% battery @ 806 MHz w/ SetCPU.
I want more than 748. Plain and Simple. :(
im noticing that.... the screens real buggy and wacks out and randomly selects stuff when i try to scroll or type. how would i go about reverting to Reborn ROM 2.2.3? or is there a more recommended path you or someone else may know of?
Wait for the next gROM and stick with the current one till then. I i'm sure you won't be disappointed
i just dont know if i can deal with tourettes screen mode due to my dumb @$$ flashing gingerkernel. :/
will the next release of gROM be OC'd? and less skittish?
essentially what i want to do is either go back to 2.2 and use Reborn or some other ROM. or resolve this edginess of the 2.3.3 ROM. any ideas out there?
again i have xionia 1.2518.6 and gROM 2.3.3 with gingerkernel..... how do i remove gingerkernel to start with?? id LOVE it if someone had that info.
Yes, gROM includes its own kernel/boot.img, so dirty flash will replace the one GingerKernel put in place.
Thank you both so much for your help :) Runs like clockwork now. with a few rusty gears but thats expected of a fresh ROM, I can't wait for the next in the gROM lineup to appear. :)
What do you mean a custome battery
What do i mean? well whe i can post a thread with a picture, i'd love to show you. someone posted a review regarding the 3600 mAh extended optimus battery from china, well i got ghetto clever and decided to take that battery and hotwire the two lithium packs it has to the stock optimus S battery and its control board. so the battery still is recognized as the stock 1500 mAh but it totals in excess of 5000 mAh. i cant put a BACK* on the phone, but scotch tape helped a load. ;) if you dont mind a 3/4 inch protrusion from your phones back then this mod is excellent for you overclockers and power users. I can get 40 hours of off and on heavy usage of the phone, from netflix, to music, to texting, to youtube to 4 hour phone calls. i can show you all how to make one if you're interested. it does take away from the aesthetic appeal of the phone. for sure.
Sure would atless to look at an see what i would need to do it sounds like sone fun
It really is man. I get epic battery life, and stock charger only take an hour and a half longer to charge the battery.
aaronr
