cant do with unrevokedgot a little android with yellow exclamation mark had to battery pull.. cant believe i rooted a stupid day before this came out
Same thing...got the android and yellow exclamation mark.
I did the Ota update this morning, but my software number is showing as 3.29.651.5! Shouldn't it be .6?
people, i think the yellow exlimation point and the triangle is not because you are rooted but because the update is not in the correct folder..its not being recognized correctly.
i'm rooted and i did it fine. still have my root and all apps ect.
Did you get unrooted after applying update.zip? Is it just a matter of running unrevoked3 again? Does it matter that I didn't use unrevoked to root? (I did it back when it was more complicated and unrevoked only gave temporary root permissions) I'm currently running the "official" rooted Froyo ROM that was posted a day or so after the official update came out so that may not matter anyway
rooted w/ unrevoked 3...
downloaded zip via android central. Changed name of zip to Update.zip
then had to move zip from SD/download/Update.zip to SD/Update.zip for the recovery to work....
update...
damn this thing runs smooth now. avg 53 FPS (used FPS2D app)
I don't see any difference. Are the changes really that noticeable?
This is what worries me. I have Unrevoked 3 and I want this OTA. Sure I could download and install the ROM from XDA that is already rooted, but some folks are saying it has 4G issues so I'm not confident there.
Maybe I'll try pulling the trigger now on the OTA and see if I get the same thing.
I had the same problem. I connected to WiFi and signed into the Google Talk app with no problem. Once signed in, I disconnected from WiFi and went back to 3G. I signed out of the Google Talk app and and signed back into the Google Talk app with no problem.
Titanium restore isnt working anymore. I get an instant reboot when I start restore. :\
downloading now via 3g. i had to turn the 4g radio on before it could find the update. weird
L
I couldn't get the update either so I tried 4g and the update appeared...weird
