[PSA] Rooting the new 2.3 is [ITS POSSIBLE GUYS!!!] 8/14/11
Ok, so when you first open the Revolutionary Rooting file and have your device plugged up, it will give you your sn# in the command prompt.
I would use a second command prompt just in case and also leave the command prompt for the rooting file open.
Remove HTC Sync as some had problems with it being installed. I would uncheck fastboot as your phone will reboot a few times. Yeah just follow along with the video and you'll be fine
TY. I knew they would get it done. And tons of people thought it wouldnt happen
Update: Think something is tweaked in the phone. Done a few more battery pulls and messing around and finally got it into recovery. Flashing back to stock and seeing if it does it again and if so I will be taking it into Sprint. Load off my chest right now.
For anybody having a prob with the beta key, I had to do the process twice, the second beta key it gave me worked fine. it was a different key and went through ok. More than likely i was just typing it wrong.
Acquired s off but when trying to install super user says bad zip file any body have a good copy to link to me please last thing I need to do
SmokeCrawler if youre out there can you recommend a decent stable Rom to flash. it would be appreciated. I was thinking you have tried many and could recommend one.
Here lately I have slowed down on flashing new roms. I've been rooted since October so I got tired of always setting it up to my liking.
For AOSP (Android Open Source Project) the 3 I would recommend is
CM7 Don't forget gapps
Deck's gapps also needed
Vaelpak4 Gapps included
As for Sense I haven't used one in a long time, but here are some popular roms
Synergy
MikG
If anyone thinks of something else feel free to chime in :)
I think you posted the best ones, SC.
I like Decks alot so that's my first recommended AOSP rom.
MikG, Synergy and Kinged Kingdom for the 2.1/3.0 sense hybrid
Synergy Kingdom, Kinged Kingdom for the pure 3.0 sense roms
Reactions: SmokeCrawler
Hey smoke how ya doing?
Anyway if you do use decks rom I highly recommend getting gtalk and the miui camera, because decks camera isn't full screen! Other than that I say smokecrawler is on the mark with those recommendations! By the way I knew this time would come! Yehawwwwww!
Sent from Looney Tunes Central!
off8485
