[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 2.1 -8/24/11- GB 2.3.4 - Best Ever!
i have a question for anyone that knows the steps on how to update this ROM from 2.0 to 2.1 ?? the update app that was included does not even work ..so whats the alternative on future updates when the updater app does not work do i have to download the 2.1 zip and flash it all over again like i did 2.0? if so let me know thanks ... who ever helps me will get 100 cool points lol holla at me buds :cool:
The OP states... The ROM Updater does not boot into recovery. Do not use that option. Use it just to download. When the download is done, reboot into recovery using the power menu you get when you hold down the power button. The file will be downloaded to "/CleanROM/" Just flash it from there.
Can I have my cool points now? Also, can I redeem those for "Internetz" instead? I still have a coupon for internetz I haven redeemed yet :)
I just updated my 2.0 version to 2.1. I downloaded the 2.1 zip file. Rebooted into recovery. Wiped Cache, Wiped Dalvik Cache and installed 2.1 zip. Reboot. So far no problems.
As far as i was told, the Rom Updater will not boot into recovery yet, so its just to be used as a means to download the zip file. You will still need to manually boot the phone into recovery to flash zips. Think this is something he is still working on.
Indeed!
Reactions: yibrushn
thanks for the awesome rom! have a coffee on me :) or a happy hour beer.
So, I had no problems with my cell service when I was running 1.2. I did factory reset from recovery flashed 2.0 and since then my phone has been roaming only. When I flip it to sprint only, it has no service. OTHER sprint phones in my house are working fine. I cleared cache and what not and flashed 2.1 a little bit ago, and same problem. In sprint mode only no service. 2 other sprint phones next to me have sprint coverage no problem.
Any ideas on what happened? Any ideas on how to solve? I did a prl update, I did a device configuration update. Still no Sprint coverage.
Do this.... Flash the Stock ZIP Rooted that I have and tell me what your results are.
Also, can you capture your radio version (aka baseband) from the settings -> About Phone -> Software?
Here is the stock Rooted I am reffering to: http://forums.androidcentral.com/ht...om-stock-rooted-2-08-651-2-sprint-update.html
We can go from here... Also what root and recovery method are you on?
After a CleanROM 2.1 flash:
My signal strength reads lower than a EVO setting right beside it.
I can't dial out.
I get the following message:
The process com.android.phone has stopped unexpectedly. Please try again.
(force close)
I can select a contact and call them, but no dialing from the pad.
I can't dial out.
(force close)
Thats weird. I cannot replicate that. Did you wipe and install fresh? Also, what radio version are you on?
Add to ROM Updater: Sprint App Pack
Will install the following Sprint Apps
Sprint TV
Sprint Radio
Sprint Zone
Telenav
Sprint Mobile Wallet
I can't dial out.
(force close)
I did not do the wipes, I had a fresh 3d.
baseband
.97.00.0518
baseband
.97.00.0518
Ok, here is what I would do....
Step 1:
First start off with a complete fresh wipe. Reboot into recovery, select Wipe / Factory Reset. Then reflash the ROM. If that doesn't resolve it let me know and we can move on to other issues. It sounds like you just need to wipe.
Step 2 (optional): Flash the updated Radio. I can grab it for you if you need it.
If you know where the radio is that would be great.
I can call out, I just can't use the number pad, dunno if the radio has anything to do with that.
No, but it doesnt hurt to stay up to date. I think the issue software related. Try the wipe method first.
Edit: Here is the link to the radios: http://forum.xda-developers.com/showthread.php?t=1223979
I flashed this file and was fine: PG86IMG_2.08.651.2_firmware_nohboot.zip
wiped, reflashed.
heh, now I'm pissed. me=dumby
I can dial, just not sprint * codes. Man, that sux, I wiped for nothing. Gotta set that crap up again. Sprint * codes give me the error.
wiped, reflashed.
What specific code gives you the error?
And no you are not dumb. Just a newb and we were all newbs once!
*2 Sprint support.
You will need to install the Sprint App pack I just posted. You need sprint zone.
EDIT: Before yo do that I am going push an update for Just sprint Zone so you dont have to take all the extra's if you dont want them.
Give me 5 minutes
Ok Sprint Zone has been pushed to ROM Updater.
Give me 5 minutes
All is working now.
Was scared for a bit. Haven't done the radio yet. Gonna try it out with real calls, when my buds are awake.
Thanks.
I am at work for the night, and am stuck at 1x speed. I'll have to wait and do this tomorrow afternoon (Pacific time)when I wake up.
baseband version = 0.97.10.0530
prl 21080
I am using the teamwin recovery. I had temp root, and then used the revolutionary pre03 or something like that. Not the current 4 one.
Have S-Off Hboot 1.40.1000
I lost the 3d Spiderman game, what is the easiest way to get that back? My boy likes it a lot.
thanks,
Also, Android Market won't download a thing for me. Has anyone found a fix for this? Sticks at starting download. I use a google apps account, but even if I try a non-apps account it still won't download.
lordnico86
