[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 2.3.SP1 - 9/4/11- GB 2.3.4 - The Smoothest Yet
can anyone please tell me the Addon/Theme server for ROM updater...I cannot see any servers installed in my ROM updater app. Thanks
This is what is posted in post #2
Scott in Post #2 said:
========How to Configure and Use ROM Updater=========
Start ROM updater app
Press phone Menu Button and select configuration
Select Addon/Theme Update Settings
Select Manage Addon/Theme Servers
Press phone Menu button
Select Update Featured Addon/Theme Servers and select yes
Themes by scrosler will show up, press back button 3 times.
Press phone menu botton and select Check now
Theme list will be populated
Download theme of choice
NOTE: The application is still in development! At this time you cannot automatically flash the download from inside the app! When the download completes select "Apply Later" Now use the phones power button to boot into recovery and flash the downloaded theme. It will be located in "CleanROM".
This app was developed by puertoblack2003 and was ported with permission to CleanROM!​
Updates in Version 2.3
Removed: Teeter, Gooogle Music, XDA App, Google+
Hate to keep asking about nit-picking things but I'm running 2.3 SP1 and all of these apps are still loaded?? What's up with that?? I'm not worried about them but was just curious as to why they are still there.
Sounds to me like you didn't wipe before you installed?
Did you do a complete wipe?
Good call. I just did a cache / dalvik wipe not a full wipe, and I still have those apps too. I'll live with them being there for now.
No longer get 3g. Only get 1x.. have tried uodating profile and prl several times. No luck
Got it. Thanks
Im trying to flash the kernel through fastboot but it keeps saying error cannot load boot.img. I put it in the root of sd card. any sugestions? Also can i try using Flash Image GUI on htc unlock method?
1. Is the kernel on the root of your SDCard?
2. You can try to flash anything any way you want ;) Cant say it will work but you can always try!
I dont know much about that program. If you post a link I can take a look.
To use fastboot to flash a boot.img or .img of any type.
1)place said .img into the tools folder of sdk you should see a file in folder called (fastboot)
2)boot phone into bootloader
3)connect to pc
4)run command
Code:
fastboot flash boot boot.img
If it's not a boot.img it won't work.This all assumes you have complete root with eng.bootloader. The app Flash Image should work just fine to do this also.It will flash any .img just be careful and make sure to have a nadroid
3)connect to pc
4)run command
Code:
ok so it goes in the sdk and not on the root of sd card?
That's the only way i know to use fastboot to flash a .img is to have the file in the sdk/tools folder. Havung it on the sdcard mean you would need extra commands to copy the boot.img from the sdcard onto the phone.
Just want to double check it is a boot.img,and not a kernel or zImage right if it's one of them two then you will have to use a zip to flash.
It's the kernel from clean rom. I read that boot.img is the file I need to flash it.
heritagevine05
