[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 2.3.SP1 - 9/4/11- GB 2.3.4 - The Smoothest Yet
I've only used one other 3D ROM, but I've used 3-4 different ones on my EVO4G. CleanROM is truly a great ROM and like ChadH42 said, the support is second to none. (actually better then all in my book).
Thank you sir!
Hey does the Cleanrom 2.3 SP1 Full Rom contain the Hotspot fix in it? Installed it and i still received the message
We actually call that Dev Error... lol
I thought i fixed it when I made the SP1 ROM file but I didint. You need to use the SP Hot Spot Fix in the ROM Updater App. See post #2 for ROM Updater instructions!
Thanks so much for your work scrosler. Great rom. One question. Is there any way to get this back speaker any louder?
Did we figure out the whole only gettng 1x signal issue? I just flashed the sp1 hoping that issue was gone but im back to 1x signal again.
Sent from my SCH-I905 using Tapatalk
I pop in and out between 1x and 3G, I think the rom is more "sensitive" to what the data speeds are and shows 1X when appropriate. I travel to and from work on the train and the "dead areas" always showed up as 3G on stock, they show as 1x on this rom. In other words, I could be getting crappy speeds on the stock rom and it would show 3G. Same crappy speed on this rom, but it accurately reflects the 1X. Does that make sense? Is that even possible? I'm pretty convinced the 1X issue I had was due to the PRL thing going on with Sprint.
I've been playing around with some other roms and keep coming back to this one. No need to even look at others anymore. Make sure your PRL is correct and go to a place where you get good coverage. Do a speed test and go from there. I'm pretty sure it's not the rom but I could be wrong.
Good luck!
Good luck!
If you are constantly stuck in 1X when you KNOW you should have 3G its a settings issue...
We went over this in depth on XDA. Here was the final conclusion that resolved the issues for everyone with the problem: xda-developers - View Single Post - [ROM] CleanROM 2.3.SP1 - 9/4/11- GB 2.3.4 - The Smoothest Yet!
Hmm ive tried all that was mentioned and i still only have 1x.
I dont know what to tell you at this point. Maybe you really have 1X? Could that be a possibility?
But the hot spot still only works on 3G data whereas Wireless Tether works on either 3G or 4G. Nevertheless it's useful to have the Hot Spot as a backup in case Wireless Tether starts acting funky (as it does on occasion).
Correct... And... The Sprint Hotspot allows wired tether on 3G too!
Weirdest thing. I got home and reflashed and now I have 3g. I have seen the 1x more though after it started working than I have ever seen before but maybe the stock Sprint rom masks when it's actually in 1x.
You are correct about Sprint masking it! (nice, heh?)
So its working the way it should now?
Yeah everything appears to be working great and I'm really loving the screen transitions.
Yes, I love those to. Some people complain about them but I love them. If you do get sick of them you can shut them off int he Display Settings Menu.
Hello,I just flashed cleanROM 2.3.SP1 and opened ROM updater and followed the instructions from post#2. I still can't seem to get it to display the list of available themes or add on's? I see the,"Themes by Scroler" but when I go back and check for updates I get nothing? Any advice to what I might be doing wrong? Thanks
You just happened to pick the wrong time to do updates. I am updating the theme server now. I am adding a couple pieces of coolness.... Give me like 15 minutes...
owo Emmanuel
